Local Time 00:39 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with ADC
lew247
Posted: 11:22pm 10 Mar 2016
I;m trying to get wind direction to work
My wind vane is a 10k pot and it gives a nice linear voltage reading between 0 - 3.3V depending on which direction it's pointing
I cannot get the reading from the adc to work properly
I'm using a micromite+ to test the code and pin 62 should be an analog pin
here's a sample of the code thats really bugging me
[code]
Const wDirPin=62 'connected to the centre pin of the potentiometer
Setpin wDirPin,Ain
Sub WindDirProc
wDir=Pin(wDirPin) 'wdir=Pin(62)
select case wDir
case 0.993 to 1.023 'if the voltage on wdirPin is between 0 and 0.031 it should print "wheading North"
wheading = North
case else
case 0 to 0.031
wheading=North
CASE ELSE
case 0.032 to 0.096
wheading = NNE
end select
End Sub
print "Heading"; wDir[/code]
No matter what I try and do it always prints wheading 0
Any ideas why? or is there a special way to measure the voltage on an analog input pin
I did read the manual and I did try other options with case such as using case IS =0 and >=0.32 and various permutations around this
Edited by lew247 2016-03-12
Posted: 11:33pm 10 Mar 2016
Try this (untested!)
[code]
Setpin wDirPin,Ain
do
print "Heading"; WindHeading(PIN(wDirPin))
pause 5000
loop
FUNCTION WindHeading(value) AS STRING
SELECT CASE value
CASE 0.993 to 1.023 'if the voltage on wdirPin is between 0 and 0.031 it should print "wheading North"
WindHeading = "N"
CASE 0 to 0.031
WindHeading = "N"
CASE 0.032 to 0.096
WindHeading = "NNE"
CASE ELSE
WindHeading = "?"
END SELECT
END FUNCTION
[/code]
Edited by MicroBlocks 2016-03-12
lew247
Posted: 12:30am 11 Mar 2016
Thanks Jean, I tried many variations of that but it just wont work
from what I can see with what you suggested
MEANS
print "Heading"; result of direction function(value of pin62) =
the WindHeading function from what I can see has no way of knowing it's meant to be the value of pin62 (0-1023) ?
in my example
wHeading=Pin(wDirPin) 'wheading = value of pin62 (0-1024)
told the program that the value of pin62 = wheading then the Case "SHOULD" have decided the directionEdited by lew247 2016-03-12
Posted: 12:48am 11 Mar 2016
Does PIN() give a 0-1024 (or 1023) value?
If it does, it needs dividing by 1024 for the code to have a chance to work.
Posted: 12:52am 11 Mar 2016
A function will work with the paramaters that you supply.
The name of that parameter is then a local variable for that function only.
So PIN(wDirPin) which is exactly the same as writing PIN(62) will return the value of pin 62.
Lets imagine it is 0.123.
It will then use that value to pass to the function.
Equivalent to WindHeading(0.123)
So the function does not know anything about any analog pins, and it doesn't need to. It's only purpose is to translate the value into something meaningful.
But first things first. You need to know if you are getting good values from the analog port.
A tiny program that does only that will make sure.
[code]
SETPIN 62, AIN
DO
PRINT PIN(62)
PAUSE 1000
LOOP
[/code]
Once that works you can add the function again.
lew247
Posted: 01:21am 11 Mar 2016
Thank you so much
I never would have thought of just trying it on it's own
Tring the print PIN(62)
it gives a voltage reading of 0-3.3V depending on which direction it's pointing.
I'll carry on with it now and sort it out (hopefully)
lew247
Posted: 02:26am 11 Mar 2016
I really don't get it
IF I just measure the voltage on pin 62 using the program it works and prints out the voltage
If I try and get it to do anything else it just will not work no matter what I try
The program below is the closest I have got to what I want
it prints [quote]Direction: YES[/quote]
The problem is - I had pin 62 set to 0V even changing it to 3.3V it still said the same
its like the conversion using the CASE is not working
I have tried every combination of CASE I could reading through the manual, and even some that are not in there, I've tried 0 TO 1,5 and 1.6 TO 3.3 and that does not work
which is why I changed to <= symbols
it "SHOULD" be working, the micromite does measure the voltage and print it out IF I don't use the sub WindDirProc
I'm completely stumped
This is the full program
[code]
SETPIN 62, AIN
dim Wheading as string
Pause 1000
WindDirProc
Print "Direction: "; wheading
loop
Sub WindDirProc
select case Pin(62)
case IS > 1.51, is <= 3.3 'if the voltage on wdirPin is between 0 and 1.5 it should print "Yes"
wheading = "Yes"
case is <= 0, is <= 1.5
Wheading = "NO" 'if the voltage on wdirPin is between 1.51 and 3.3 it should print "No"
end select
'END function
End Sub
[/code]Edited by lew247 2016-03-12
disco4now
Posted: 02:49am 11 Mar 2016
I think the case statement below does not do as you expect. It is true when it finds either of the conditions true. It does not require both to be true, the test IS <=3.3 will always be true and hence this case is the one selected.
case IS > 1.51, is <= 3.3 ' ALWAYS true if EITHER condition met.
Gerry
F4 H7FotSF4xGT
lew247
Posted: 03:00am 11 Mar 2016
How can I get it to compare readings then and print a different value for each reading?
I've tried
[code]
select case value
wheading = "N"
CASE ELSE
CASE 0 to 0.031
Wheading = "N"
CASE ELSE
case 0.97 to 0.160
wheading = "NE"
CASE ELSE
case 0.161 to 0.224
wheading = "East"
[/code]
and using this format doesn't work eitherEdited by lew247 2016-03-12
Posted: 03:09am 11 Mar 2016
You should only have one "CASE ELSE" and it must be the last.
so try this:
SETPIN 62, AIN
do
value=pin(62) 'are you forgetting this?
select case value
wheading$ = "N"
CASE 0 to 0.031
Wheading$ = "N"
CASE 0.97 to 0.160
wheading$ = "NE"
CASE 0.161 to 0.224
wheading$ = "East"
CASE ELSE
wheading$="not yet assigned
end select
print wheading$
pause 1000
loop
Edited by matherp 2016-03-12
lew247
Posted: 03:22am 11 Mar 2016
Thank you again, I'll never be able to repay all the help I've received
That now works, I'll now try it with all 32 directions defined and "hopefully" it will work still
lew247
Posted: 04:07am 11 Mar 2016
Working perfectly now
Thank you everyone so much especially MicroBlocks and matherp for your help, and also to MikeO who spent a very painful 2 days through email helping me with various stuff relating to this.
This forum is amazing (in a very good way )
Posted: 06:32am 11 Mar 2016
  lew247 said  My wind vane is a 10k pot and it gives a nice linear voltage reading between 0 - 3.3V depending on which direction it's pointing
Hi Lewis,
Glad you've made good progress today with this.
Out of interest, is your Wind Vane effectively a continuous rotation pot? Apologies if you have posted a link previously, but any chance of more details about the vane (did you purchase - or is it home made?)
Thanks,
WW
lew247
Posted: 07:21am 11 Mar 2016
Yes it's a continuous rotation pot 20K
[code]
Wind Speed
Measurement range 0-100 mph (standard)
0-50 m/s, 0-100 knots, or 0-200 km/hr (optional)
Speed constant 1.25 mph = 1 pps
75 mph = 60 Hz (pps)
Transducer type Reed switch
Speed threshold 0.8 mph
Accuracy 1 mph or ± 3%
Wind Direction
Range 0-360 degrees azimuth
Transducer type Potentiometer, 20k ohms, conductive plastic
Potentiometer gap 5°
Azimuth accuracy ± 3°
Threshold 1.2 mph
Bearings Bushing
The wind sensor output signal is a reed switch closure. There are three switch closures
for each revolution of the cup assembly. [/code]
The only reason I have this one is I got it at a real bargain price on Ebay. I'd never had considered it otherwise
User manual www.novalynx.com/manuals/200-ws-23-manual.pdf
