Forum Index : Microcontroller and PC projects : ssd1306 oled I2C driver
| viscomjim Guru Joined: 08/01/2014 Location: United StatesPosts: 925 |
Can anyone confirm that the drivers referenced HERE in this thread are the latest and greatest for the SS1306 I2C oled display? And, can you use fonts with this like the other displays? Thanks!!!!! |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11907 |
Latest driver for the SSD1306 is here This is the only version that integrates with the MM firmware graphics calls (text, circle etc.) It only support SPI displays, not I2C, and only works on the 28 and 44-pin parts It is possible to make this work on the 64-pin. However, I can't make it work on I2C as I don't have access to the I2C routines from a Cfunction and I2C is too hard to drive direct. |
