Local Time 09:25 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : NEC IR Transmission?
Frank N. Furter
Posted: 01:48am 19 Feb 2016
Hi to all!
Is there a way to send a NEC IR-protocol with our Micromite?
I know we can receive it and we can send Sony-protocol but I need NEC as transmitter to control my Pioneer CD changer...
THANKS!
Frank
Posted: 02:18am 19 Feb 2016
Matherp!
Your're up!
Not sure if this can be done with a Cfunction,but perhaps?
Posted: 03:42am 19 Feb 2016
This really would be an excellent 'feature' (even to the firmware).
Only thing is though, there maybe too many 'standards' (from my early days when playing with the Apple IR remote).
Be interesting to see how this thread develops!
Posted: 06:33am 19 Feb 2016
  Quote  Matherp!
Your're up!
Your wish is my command
NECSend pin_number, device, code
e.g
NECsend 2,255,1
Note: if you send the above to a Micromite it will report "255,128". I'm pretty sure that Geoff has got the bit order the wrong way round but await his comments
And then we get onto the tricky bit about the device address. There are two versions of the NEC code , one sends a 8-bit address and then the inverse of the address as a check byte. The other sends a 16-bit address.
Geoff's code assumes a 16-bit address. I have implemented the send function such that addresses <256 are send in normal mode, addresses > 256 are sent in extended addressing mode.
The code should run on any flavour of Micromite and at any clock speed although slow speeds may produce poor results as the timings will not be very precise.
Just connect your IR LED to any DOUT serial port. The -ve connection on the LED should be connected ground and the +ve to the Micromite port via a resistor (330ohm works for me) i.e. positive logic. The code will automatically set the chosen pin as an output.
Enjoy
Csub NECSend
0000001A
'high
00001021 40824800 0045102B 10400008 00804021 40024800 0048182B 1460FFFD
0045102B ACC70000 1440FFFA 01044021 03E00008 00000000
'low
ACA60000 00001021 40824800 0044102B 10400005 00000000 40024800 0044102B
1440FFFD 00000000 03E00008 00000000
'main
27BDFFB0 AFBF004C AFBE0048 AFB70044 AFB40038 AFB30034 AFB20030 AFB1002C
AFB00028 AFB60040 3C109D00 AFB5003C 8E02009C 00809821 3C044795 24844E00
00C0A021 0040F809 00A08821 AFA20020 8E02009C 3C0444DE 0040F809 248438E4
0040B821 8E02009C 3C044414 0040F809 248425ED 0040F021 8E02009C 3C04435E
0040F809 248438E4 AFA2001C 8E02009C 3C0442DE 0040F809 248438E4 AFA20024
8E640000 8E020024 24050007 0040F809 24120001 AFA20018 8E640000 8E020024
0040F809 24050005 AFA20014 8E020028 0040F809 8E640000 8E230000 8E240004
00529004 306500FF 14800006 8E870000 54800005 38A300FF 2C620100 54400002
38A300FF 7C633A00 8FA20014 3C159D00 00078C00 AC520000 8E640000 8EA20010
38E700FF 00073E00 02258825 02278825 00003021 24050008 00031A00 0040F809
02238825 8FA30018 8EA20004 24044E20 0040F809 AFA30010 8EA20000 3C040008
3C03BF88 AC641064 3C03BF88 AC601068 8C440000 8EA20080 00002821 0040F809
8EB30064 00408021 8EA2009C 3C044000 0040F809 8FB40014 00402821 0260F809
02002021 0040B021 8EA20064 8EB0007C 02E02821 0040F809 02C02021 0200F809
00402021 00409821 8EA20064 8EB0007C 03C02821 0040F809 02C02021 0200F809
00402021 0040F021 8FA5001C 8EA20064 8EB0007C 0040F809 02C02021 0200F809
00402021 AFA2001C 8FA50024 8EA20064 8EB0007C 0040F809 02C02021 0200F809
00402021 0040B821 8FA50020 8EA20064 8EB0007C 0040F809 02C02021 0200F809
00402021 8FA60018 00402021 02E02821 02403821 0040A821 0411FF4F 00000000
8FA4001C 8FA50014 02403021 00008021 0411FF57 00000000 24160020 8FA60010
02A02021 02602821 02403821 0411FF42 00000000 32220001 03C02021 02802821
02403021 10400005 0260B821 0411FF48 00000000 10000007 26100001 02602021
02802821 02403021 0411FF41 00000000 26100001 1616FFE9 00118842 8FA60018
02A02021 02E02821 02403821 0411FF2A 00000000 8FA30014 3C020008 AC720000
8FBF004C 3C03BF88 AC621064 3C03BF88 8FBE0048 8FB70044 8FB60040 8FB5003C
8FB40038 8FB30034 8FB20030 8FB1002C 8FB00028 AC621068 03E00008 27BD0050
end csub
C source for those interested
#define _SUPPRESS_PLIB_WARNING
#include <plib.h>
#include "../cfunctions.h"
void high(unsigned int dwell, int duration, int portinv, int mypin){
unsigned int next_clock=dwell;
unsigned int current_ticks=0;
asm volatile("mtc0 %0, $9": "+r"(current_ticks)); //set the current number of ticks to 0
while(current_ticks<duration){ //send leading pulse
do{
asm volatile("mfc0 %0, $9" : "=r"(current_ticks));//get the time in ticks since zeroed
}while(current_ticks<next_clock);
*(volatile unsigned int *)portinv=mypin;
next_clock+=dwell;
void low(int duration, int portclr, int mypin){
*(volatile unsigned int *)portclr=mypin;
void main(long long *pin, unsigned long long *devin, unsigned long long *codein){
float IRfreq=LoadFloat(0x47954E00); //38.222KHz * 2
float us562 =LoadFloat(0x44DE38E4); //562.5 usec
float us1687=LoadFloat(0x441425ED); //1.6875 ms
float ms4=LoadFloat(0x435E38E4); // 4.5 msec
float ms9=LoadFloat(0x42DE38E4); //9 msec
float tick_rate;
unsigned int us562i,us1687i,ms4i,ms9i,dwell;
unsigned int portinv=(int)(volatile unsigned int *)GetPortAddr(*pin,LATINV);
unsigned int portclr=(int)(volatile unsigned int *)GetPortAddr(*pin,LATCLR);
int mypin=1<<GetPinBit(*pin);
unsigned int devinv,dev=*devin & 0xFF;
unsigned int code=*codein;
if(*devin>0xff){
devinv=(*devin>>8) & 0xFF; //extended address mode
} else {
devinv= dev ^ 0xFF; // normal invert of single address
unsigned int codeinv= code ^ 0xFF; // get the inverse of *dev
int j;
unsigned int transmit = dev | (devinv<<8) | (code <<16) | (codeinv<<24);
ExtCfg(*pin,EXT_DIG_OUT,0);
uSec(20000);
mT4IntEnable(0); // disable clock interrupt
tick_rate = FDiv(IntToFloat(CurrentCpuSpeed),LoadFloat(0x40000000)); //get the number of clock ticks per second
us562i=FloatToInt(FDiv(tick_rate,us562));
us1687i=FloatToInt(FDiv(tick_rate,us1687));
ms4i=FloatToInt(FDiv(tick_rate,ms4));
ms9i=FloatToInt(FDiv(tick_rate,ms9));
dwell=FloatToInt(FDiv(tick_rate,IRfreq));
high(dwell, ms9i, portinv, mypin);
low(ms4i, portclr, mypin);
for(j=0;j<32;j++){
high(dwell, us562i, portinv, mypin);
if(transmit & 1){
low(us1687i,portclr, mypin);
} else {
low(us562i,portclr, mypin);
transmit = transmit >> 1;
mT4IntEnable(1); // enable clock interrupt
Edited by matherp 2016-02-20
Posted: 07:11am 19 Feb 2016
THANK YOU!
This is brilliantly useful
Posted: 03:00am 20 Feb 2016
I realised belatedly the CFunction was somewhat over engineered so here is a simpler (and smaller version)
[code]CSUB NECSend
0000000E
'high
'main
27BDFFB0 AFBF004C AFBE0048 AFB70044 AFB5003C AFB30034 AFB20030 AFB1002C
AFB00028 AFB60040 3C109D00 AFB40038 8E02009C 00808821 3C044795 24844E00
00C09821 0040F809 00A09021 AFA2001C 8E02009C 3C0444DE 0040F809 248438E4
0040B821 8E02009C 3C0442DE 0040F809 248438E4 AFA20020 8E240000 8E020024
24050007 0040F809 24150001 AFA20018 8E240000 8E020024 0040F809 24050005
0040F021 8E020028 0040F809 8E240000 8E430000 8E440004 0055A804 306500FF
14800006 8E670000 54800005 38A300FF 2C620100 54400002 38A300FF 7C633A00
3C169D00 AFD50000 8E240000 8EC20010 00079400 38E700FF 00073E00 02459025
02479025 00003021 00031A00 24050008 0040F809 02439025 8EC20004 240407D0
0040F809 AFB50010 8EC30000 8EC20080 8ED30064 8C640000 8FA30018 00002821
00008821 0040F809 AFA30014 00408021 8EC2009C 0040F809 3C044000 00402821
0260F809 02002021 0040A021 8EC20064 8ED0007C 02E02821 0040F809 02802021
0200F809 00402021 00409821 8FA50020 8EC20064 8ED0007C 0040F809 02802021
0200F809 00402021 0040B821 8FA5001C 8EC20064 8ED0007C 0040F809 02802021
0200F809 00402021 8FA60018 00402021 3C030008 0040A021 3C02BF88 AC431064
02E02821 3C02BF88 02A03821 AC401068 0411FF75 00000000 AFD50000 8EC20004
24041194 0040F809 3C109D00 24160020 8FA60014 02602821 02A03821 02802021
0411FF69 00000000 8FA20010 24040232 26310001 AFC20000 8E020004 0040F809
0260B821 32420001 10400004 00000000 8E020004 0040F809 24040465 1636FFEC
00129042 8FA60018 02802021 02E02821 02A03821 0411FF54 00000000 AFD50000
8FBF004C 3C020008 3C03BF88 AC621064 3C03BF88 8FBE0048 8FB70044 8FB60040
8FB5003C 8FB40038 8FB30034 8FB20030 8FB1002C 8FB00028 AC621068 03E00008
27BD0050
end CSUB
[/code]
Geoff believes that the Micromite NEC receive code may well be reporting the wrong codes as I suspect so here is a little program that can be used to test the NECSend function. This will report exactly the codes sent and also correctly evaluate normal (8-bit) and extended (16-bit) device addressing.
Frank:
If you run the following receive program on a Micromite you can read correctly the codes from your existing controller to use in the NECSend function
option explicit
option default none
Dim integer dev,key
IR dev,key,irint
pause 1000
Loop
irint:
If (dev And &HFF) = ((dev>>8) Xor &HFF) Then ' normal address
Print brv((dev>>8),8) ,brv(key,8)
Else ' extended address
Print brv(dev,16),brv(key,8)
EndIf
IReturn
Function brv(x As integer, k As integer) As integer
Local integer n
brv=0
For n=1 To k
If x And (1<<(n-1)) Then
brv=brv Or (1<<(k-n))
EndIf
Next n
End Function
C source of the update
#include <plib.h>
do{
next_clock+=dwell;
float tick_rate;
unsigned int us562i,ms9i,dwell;
if(*devin>0xff){
} else {
int j;
uSec(2000);
*(volatile unsigned int *)portclr=mypin; uSec(4500);
for(j=0;j<32;j++){
*(volatile unsigned int *)portclr=mypin; uSec(562);
if(transmit & 1) uSec(1125);
high(dwell, us562i, portinv, mypin); //stop bit
Edited by matherp 2016-02-21
Frank N. Furter
Posted: 07:15am 21 Feb 2016
Hi Peter,
you are amazing!
THANK YOU VERY, VERY MUCH!!!
...it's very difficult to find a special CD in a 301 capacity disc changer!
Now I can built a intelligent IR-Remote to find my CD's! That's really great!
Frank
P.S.: ...is it possible that you are related to DATA from the StarTrek Next Generation?
Posted: 02:20pm 21 Feb 2016
He is Lore......
Frank N. Furter
Posted: 08:55pm 21 Feb 2016
No, no, no - Lore was a bad guy!
...and Peter is a genius!!!
Phil23
Posted: 05:35pm 21 May 2016
  matherp said
  Quote  Matherp!
Your're up!
e.g
NECsend 2,255,1
Enjoy
Been Searching a bit on this topic.
Not sure what Peter's Functions capabilities are, but is the able function to send ANY command from ANY remote possible?
If this was paired with a Read or learn Function, it would let users the MM to control any device with an IR remote.
Obviously there may be limitations.
Phil.
PS my main understanding of IR remotes is that some types tend to go missing more than others, while certain ones gravitate to one of several known locations.
Posted: 05:56pm 21 May 2016
There are many, many different IR protocols and it would be impossible to implement them all.
My guess is that most learning remote controls do their learning by measuring the timing of the IR signal and then replicating that, ie they do not know what the content means. This is no good for the Micromite and far too messy to implement.
piclover
Posted: 02:49am 22 May 2016
  Geoffg said   There are many, many different IR protocols and it would be impossible to implement them all.
In my very own view, none of the IR protocols should even be part of the MM2 firmware (since none of those protocols are predominant on the market: there are also Philips' RC5/6, Toshiba's, etc...).
Now that CFunctions exist, they should be implemented as such (especially since using a remote protocol in a project is not the most common occurrence). It's of course, my own opinion.Edited by piclover 2016-05-23
Posted: 10:07am 22 May 2016
Totally agree with the above statement - and IMHO it is good to leave at least the Sony protocol in MMBasic's Firmware as it gives 'beginners' the option to very easily add in IR functionality into a project using cheap Remotes available on eBay with just the addition (in terms of hardware) of a single IR detector. Put another way, Low hardware Cost, Simple Code, and potentially a Powerful end Solution.
I wrote & published some early code to decode the NEC protocol purely because I loved the styling of the Apple remote. Now that this is also implemented in the firmware I would say leave this in too. But to add other protocols I totally agree that these should be performed by user code (whether it be pure Basic code or as a CFunction).
To remove all IR decoding software from the MMBasic firmware would be a bad move IMHO as not everyone can write CFunctions. Geoff has it bang on in terms of two 'basic' protocols that can be used with just a couple of lines of code. Try doing that on a RPi, or an Arduino, or a . . . . . .
Phil23
Posted: 11:24am 08 Jun 2016
My guess is that most learning remote controls do their learning by measuring the timing of the IR signal and then replicating that.
Looks like between Sony & NEC protocols seem to cover just about everything in this house.
From what I see with most of the universals I've played with here (cheap ones), they seem to rely on a brand code table, usually printed.
I assume that then tells the remote which device code to use & what keycode to assign the buttons.
Some have a discover mode, where they try the different band codes until you acknowledge that the device has been turned on. At that point you can test other button, and if happy accept that brand code, or continue to scan others.
Once you've found the brand code you can accept that, and some then offer a learn function to correct or add buttons.
As the remote now knows the brand code & device code, I'd assume they are decoding in their learn mode, as they already know the correct device code, it's only a key code that needs to be corrected.
The Logitech's I have are setup by their web app, using a database of device & keycodes for various appliances.
The one big exception to what can be controlled by my universal remotes is the Air Conditioners.
They all use a totally different approach, sending the entire status the Air conditioner is required to be in; Heat/Cool mode, Fan Speed, Temp, swing etc, etc.
Obviously this is required to ensure the Air Con is in sync with the display on the remote.
The remotes seem to send a string of bytes, using various blocks of bits to control the various functions.
There is an interesting looking Universal Air Con Remote listed here, along with a table of brand codes.
Found an interesting Thesis done recently regarding Air Con controls;
Universal infrared adapter for air conditioners
All a bit over my head, but matherp, would be more at home reading it & knowing if the knowing the feasibility of doing something similar with a MM external function.
I'd hazard a guess that there's be users that would like to drive their Air Cons with a MicroMite.
Phil
Posted: 02:54am 09 Jun 2016
the aircon remote control is certainly an interesting one, as many units come with extremely poorly designed remotes. single buttons for each mode, on/off and temperature would suffice most users. particularly the elderly, who struggle to read the miniscule icons on many displays.
i seem to remember someone long ago on the forums tinkering with using the micromite to learn IR codes. you might care to have a dig around. it may even be possible to write something that uses matherp's micro-second timing routines that were posted recently.
rob :-)
Posted: 03:47am 09 Jun 2016
My eyesight is stil pretty ok, but even i hate to use these aircon remotes. This asks for an aircon remote challenge. :)
Phil23
Posted: 12:11pm 09 Jun 2016
  robert.rozee said   the aircon remote control is certainly an interesting one, as many units come with extremely poorly designed remotes. single buttons for each mode, on/off and temperature would suffice most users. particularly the elderly......
A friend of mine is embarking on just such a project.
Air Con control for the elderly.
His intention is to have the micro take control of the air con.
Provide a pass thru function so a degree of control is still available.
The primary purpose is to have the micro monitor the humidity level & then use the air con in the appropriate mode to keep it below a required level.
Should be interesting to see how the remote decoding goes.
First hiccup is the fact that the TSOP4840 I happen to have hear, don't seem to respond to any of my remotes. (Waiting on some 38kHz ones).
Is that to be expected?
Page 23 mentions that the 38kHz receivers will generally respond to 40kHz remotes,
but the 40kHz one won't see my Panasonic TV remote at all.
Phil
Phil23
Posted: 10:59pm 26 Jun 2016
Looks like my above statement was a fail....
Panasonic TV's seem to use Phillips RC5.
Has anyone written anything for that?
Phil.
Posted: 01:32am 27 Jun 2016
  Quote  Has anyone written anything for that?
You can do it using this routine using the circuit in the last post
Frank N. Furter
Posted: 09:37am 15 Dec 2017
@Peter:
  Quote  If you run the following receive program on a Micromite you can read correctly the codes from your existing controller to use in the NECSend function
It looks like your test program of the first page contains an error regarding the extended NEC code.
I used it with remotes that use the "normal" NEC code - everything works as desired.
However, I failed with a remote control using the "extended" code!
I read 256 as address with the program from a remote control. When I sent this address my receiver did not respond. With the oscilloscope I read and decoded 65025 from the original remote (using the document linked on the first page)
If I send this address now everything works!
The transmission routine works perfectly (many thanks to Peter!!!)
Frank
