Local Time 07:43 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM code
Chrisk
Posted: 07:39pm 16 Feb 2016
Hi Guys
I wish to NOT carry out a particular function (prevent a fan from coming ON) between the hours of 6pm and 8am the next day.
I have no idea where to start.
Can someone help with the code for this.
I am using a CMM with Ver4.5
Chris K
Posted: 08:48pm 16 Feb 2016
I don't have a CMM running to test with at the moment but this should work
controlpin = 6 ' choose a suitable IO pin
setpin controlpin, dout
settick 1000, checktime ' check the time every second
do
' do other things
loop
end
sub checktime
now$ = time$
print now$
hour$=mid$(now$,1,2)
if hour$ >="18" or hour$ <"08" then ' time is after 6pm or before 8am
fancontrol = 0
else
fancontrol = 1
end if
pin(controlpin) = fancontrol
print fancontrol
end sub
If you want to do other things with the fan control, you can use the variable 'fancontrol' to test if it is OK to run the fan.
It is OK to compare the time as a string in this case and you can also add minutes to the tests for finer control.
Chrisk
Posted: 09:00pm 16 Feb 2016
Thanks for the quick reply Jim.
It is the sub checktime that I needed.
Chris K
