Local Time 07:43 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMaximite drive size
Yourock17
Posted: 12:26am 15 Feb 2016
Hello TBS, i have a question. I'm currently writing a program that is supposed to give me the used storage on B: Drive (SD Card). I'm struggling to find a solution to how i actually get the file sizes. I have seen DIR$() but it only does the current working directory. In summary, can someone suggest some code or a command that could perhaps help me to make a program that gets the file sizes of files on the drive, including sub directories.
Thank you.
twofingers
Posted: 03:34am 15 Feb 2016
@Yourock17
I think there is still no better answer than this.
It's a working - but slow - solution (see File Selector->ReadDir)!
EDIT
Note: one call of FileSize() takes about 65ms! Maybe too slow for your application!?
Good luck!
Michael
Edited by twofingers 2016-02-16
The lone and ...
Yourock17
Posted: 10:45am 15 Feb 2016
Ok Thanks
