Local Time 00:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Strings defined with length n?
Bizzie
Posted: 05:37pm 10 Feb 2016
Hi all,
Can someone tell me why defining a string with more than n characters does not generate an error (page 55 of the MM manual indicates it should.).
See my example below :-
Using an MM with 5.1 loaded.
> dim t$(3) as string length 3
> t$(0) = "abc"
> t$(1) = "def"
> t$(2) = "ghi"
> t$(3) = "jkl"
> for i = 0 to 3 : ? t$(i) : next
abc
def
ghi
jkl
> t$(2) = "mnopq"
abc
def
mnopq
jkl
> t$(4) = "xyz"
Error: Array index out of bounds
As you can see referencing an out of bounds element does cause an error (as expected).
Rob White
plasma
Posted: 08:46pm 10 Feb 2016
T$(4) is the error
Bizzie
Posted: 09:00pm 10 Feb 2016
Yes that is correct. I put it there to demonstrate that error messages were being generated.
My question is why doesn't setting T$(2) = "mnopq" generate an error that the length of the string is out of bounds? Interestingly no data is lost (overwritten - T$(3) still has it's correct value)
Rob White
Posted: 10:34pm 10 Feb 2016
one for Geoff I think!
kiiid
Posted: 11:31pm 10 Feb 2016
You are trying to define arrays but not fixed length strings
http://rittle.org
Bizzie
Posted: 12:05am 11 Feb 2016
Thanks Kiiid,
Looks like the order in the dim statement is critical. The last part of my definition is being ignored.
This works fine :- dim as string t$(3) length 3
Rob White
Posted: 03:40am 11 Feb 2016
I got confused reading the manual about using length and arrays.
And i already program in basic for about 35 years.
Posted: 04:09am 11 Feb 2016
. . . . took me three times to read it before I spotted the 'difference'.
Bizzie's reference to:
DIM AS STRING t$(3) LENGTH 3
is a useful future reference (for me at least!).
