Local Time 00:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Need help using print and serial commands
lew247
Posted: 01:40am 09 Feb 2016
As "some of you" will know I'm extremely new to microprocessors and such like
I've got the 28pin Micromite on breadboard at the moment and I'm going to end up (hopefully) making a weather transmitter out of it and using a Micromite Plus indoors,
I'm taking it one step at a time though, and I'm stuck on what is probably the easiest thing in the work for experienced users.
I have the micromite and a DHT22 sensor and a HC-12 serial transciever connected at the moment, and I have a MPX4115A Pressure Sensor which will be connected to say pin 12 (com1 input)
I have the DHT22 on pin 15
and the HC-12 on COM 2
How do I read the temp and humidity and send it to com 2 so I can read it on the computer where I have the other HC-12 connected? (I did it this way as it's easiest for me, I can check all stages are working before I need to even start on the Micromite+ )
I've read the manual but I'm having trouble putting it all together.
I'm "guessing" that I would start with something like the following
tell the Micromite where the DHT22 is connected to - which pin*
Probably by something like this
HUMID 15, temp, humid
pause 3000 'wait 3 seconds before doing a second reading
open "com2:9600" as #1
pause 500 'pause to make sure the serial port is open properly
print #1 "the temperature is" temp "and the humidity is" humid
close #1
How do I tell it that the pressure sensor is on pin 3
I'm guessing once I have that figured out I have to name the sensor as something, then it would be something like this (somehow)
open "com1:9600 as #2
I'm stuck after this (and probably totally wrong before it)
I have to read the input on com1 which is the pressure
I then have to convert the reading to actual pressure with this formula
Pressure = ((pressureValue/1024.0)+0.095)/0.000009
Then I have to print that on com2 probably by something like
print #2 "the pressure is" pressure ' in between the temp/humidy print and closing com1 and then close com2
This is probably so easy for most of you but I think I'm totally lost
The other question - does MMBasic not use line numbers?
Edited by lew247 2016-02-10
Posted: 03:16am 09 Feb 2016
Hey there.
From the manual, page 58, it tells you how to setup the HUMID command, and the first parameter is the pin you have your sensor on - pin 15 in your example code.
MMBASIC does use line-numbers, but they are strongly discouraged, as lineless code is much more structured and easy to work with ONCE YOU GET THE HANG OF IT.
I speak from experience, as when I joined this forum, line-numbers were all I knew how to use, having never used lineless structured code before, but now that I do use it, I would never go back to line numbers.
I think the latest versions of MMBASIC still support line numbers, but others here will be able to say for sure - I don't have a MM with the latest firmware loaded handy to me right now.
You could try something like this:
HUMID 3, temp, humid
open "com1:9600" as #1
open "com2:9600" as #2
Do:Loop until LOC(#1)<>0 'Wait for pressure data
P$=Input$(LOC(#1),#1) 'Save whatever is in COM1 buffer to P$
pressureValue=asc(P$) 'Convert data to number
Print #2,"The pressure is: "; Pressure
print #2,"The temperature is " temp " and the humidity is " humid
close #2
close #1
NONE OF THAT IS TESTED - I am just throwing ideas around.
Your pressure sensor output is something we need to know - what format is it, how many bytes and what is it's output message protocol. My example code above assumes that the pressure data is a single byte, but it may well be more then that, and if so, the code example above won't work.
I use com-port handles the same as the com port number to avoid confusion, so if com2, I use handle #2 rather then #1, but that is just me. You don't need to pause 500 when opening the ports - they are open as soon as the command executes.
Sucking data out of the com port buffers uses the INPUT$ function, and assuming you need the data from the pressure sensor as a numeric variable rather then a string, I am converting the string variable to a numeric before throwing it at your pressure forumula, but you could do it all in one line PROVIDED the data from the pressure sensor is one single byte: Pressure = ((ASC(P$)/1024.0)+0.095)/0.000009
Remember that the COM ports are 8-bit ports, and as such, can't represent any one number bigger then 256, so it is quite possible that the pressure sensor is outputting multipule bytes that you have to combine into the likes of a 16-bit word or something. Need to have the pressure sensor details.
EDIT: I've just had a quick search for the pressure sensor you mention, and it is not a serial device at all, so you need an analog input pin to read it's output voltage, so pretty much all example code above won't work, as I thought you had a sensor that used serial comms, with the mention of the pressure sensor on com1 kind of statement.
You cannot use the com1 pins for the pressure sensor, as they do not measure analog voltage levels. Any of the pins marked as ANALOG can be used for this. Analog pins are dead easy to read, and you would use the likes of: pressureValue=pin(23) or combined all on one line: Pressure = ((Pin(23)/1024.0)+0.095)/0.000009, where pin23 is your pressure sensor input pin.
Bear in mind that the analog input pins cannot have more then 3v3 on them, so any pressure above about 82kPa(11.8 PSI) will need protection against over-voltage on the input pin. If you never plan to see more then 80kPa for example, then you are probably safe enough directly connecting to the MM input pin.
Edited by Grogster 2016-02-10
Posted: 03:38am 09 Feb 2016
Note that the MPX4115A is a b....r to read accurately with a uP. The output is extremely noisy. Read the datasheet and implement the filtering proposed there or something even better. FWIW, I prefer the BMP180. It needs a bit of maths to convert the data but it seems to give much more reliable readings.Edited by matherp 2016-02-10
Posted: 03:42am 09 Feb 2016
Something more along the lines of what you need would be:
SetPin 23,AIN 'Configure pin23 for analog input
HUMID 3, temp, humid 'Sensor on pin 3
close #2
If you put your pressure sensor on pin 23, that should work, but I have not tested it.
Posted: 03:45am 09 Feb 2016
@ matherp - interesting. If the output is noisy, which is not what the datasheet indicates, then it would be just about useless wouldn't it? You need a stable reference voltage or it's not worth it I would think, yes? As you say, perhaps your alternative would be much more advised. Have you done the maths to handle the data from that sensor, by any chance?
Posted: 04:01am 09 Feb 2016
  Quote   If the output is noisy, which is not what the datasheet indicates, then it would be just about useless wouldn't it?
If you read it with a multimeter it is fine. Also, I've found "proper" ADCs read it OK with some sensible filtering so it is usable. However, the PIC ADCs are marginal at best. I assume the MPX4115A has some sort of internal clocking of its circuitry and that seems to conflict with the uP ADC
  Quote  Have you done the maths to handle the data from that sensor, by any chance?
Yes
lew247
Posted: 04:11am 09 Feb 2016
Thanks everyone so far
I do have a BME280 here, The reason I didn't use it was I tried it first on the serial input on the pc, and the temperature wasn't as exact as I'd have liked.
I assume upon reading several reviews it's down to internal heating.
I never thought of using just the pressure sensor part of it though. It might be easier to use that than the MPX4115A ?
Posted: 05:53am 09 Feb 2016
  Quote  the temperature wasn't as exact as I'd have liked
The temperature measured by these sensors is used to calibrate the humidity reading. i.e. it needs to be the temperature of the humidity sensor itself
Posted: 11:47am 09 Feb 2016
Like most users, I have settled on the DHT22 for temperature and humidity and the BMP085 (or BMP180) for pressure.
Most humidity sensors go haywire after a period of very high humidity and need re-conditioning (or replacement).
The Honeywell sensors I used previously lasted 2 - 3 years before being useless.
This is the code I have running on my Micromite test server:
' reading the BMP085 pressure and DHT22 humidity sensors
' TassyJim 28 Oct 2014
OPTION clocktrim -4
DHT22pin = 26 ' 3.3V pins are OK for short leads <1 metre
DIM BMPData(2) ' store data from BMP085
DIM cal(11) ' calibration data
oss = 0 ' over sampling 0 to 3
alt = 240 ' your altitude in metres
BMP085calMEM = &HAA ' start of 11 calibration values
BMP085address = &H77 ' BMP085 address
BMP085control = &HF4 ' BMP085 control register
BMP085temp = &H2E ' BMP085 temperature command
BMP085pres = &H34 ' BMP085 pressure command
BMP085pres = BMP085pres + oss*&H40 ' adjust command for oversampling
BMP085reading = &HF6 ' register for results of reading
I2C OPEN 400, 200 ' Enable I2C. use slow speeds for long leads
PAUSE 20
z = Calibrate() ' read the calibration data
SETTICK 10000, doread
PAUSE 1000
doread
DO
LOOP
END
SUB doread
readhumidity
t=temperature()
p=pressure(oss)
p0=Psl(p,alt)
PRINT TIME$;" T(BMP085):";STR$(t,3,1);" P(sl):";STR$(p0/100,5,1);
PRINT " T(DHT22): " STR$(TEMP,3,1);" H:" STR$(HUMID,3,1)
'PAUSE (30000) ' delay 30 seconds between readings
END SUB
FUNCTION Calibrate()
' needs to be called once for each module.
' safest to do it on every program start.
LOCAL n, calMEM
calMEM= BMP085calMEM
FOR n = 1 TO 11
I2C WRITE BMP085address, 0, 1, calMEM ' first calibration location
PAUSE 1
I2C READ BMP085address, 0, 2, BMPData(0)
'print BMPData(1), BMPData(0)*256 + BMPData(1)
cal(n) = BMPData(0)*256 + BMPData(1)
IF n < 4 OR n > 6 THEN ' need to convert some to signed numbers
IF cal(n) > 32767 THEN
cal(n) = cal(n) - 65536
ENDIF
ENDIF
'print n,cal(n)
PAUSE 1
calMEM=calMEM+2 ' advance to the next calibration location
NEXT n
END FUNCTION
FUNCTION temperature()
' returns the temperature in degrees C to one decimal place
LOCAL UT, x1, x2, b5
I2C WRITE BMP085address, 0, 2, BMP085control, BMP085temp
PAUSE 5
I2C WRITE BMP085address, 0, 1, BMP085reading
UT = BMPData(0)*256 + BMPData(1)
'calculate true temperature
x1= INT( (UT-cal(6))*cal(5)/32768)
x2=INT( cal(10)*2048/(x1+cal(11)))
b5=x1+x2
temperature = INT((b5+8)/16)/10
END FUNCTION
FUNCTION pressure(oss)
' returns the pressure in pascals. Divide by 100 for millibars
' recalculates the temperatre.
' time could be saved by reading the temperature once evry 10 minutes
' when taking readings at short intervals
LOCAL UT, UP, x1, x2, x3, b5, b6, b7, pres, p
PAUSE 5
I2C WRITE BMP085address, 0, 2, BMP085control, pres
IF oss = 0 THEN ' different oversampling requires different
PAUSE 5 ' reading times
ELSEIF oss = 1 THEN
PAUSE 8
ELSEIF oss = 2 THEN
PAUSE 14
ELSE
PAUSE 26
ENDIF
UP = BMPData(0)*256 + BMPData(1)
I2C WRITE BMP085address, 0, 1, BMP085reading+2
I2C READ BMP085address, 0, 1, BMPData(0)
UP=(UP*256+BMPData(0))/2^(8-oss)
b5=x1+x2
t=INT((b5+8)/16)/10
'print "Temperature: ",t
'calculate true atmospheric pressure
b6 = b5 - 4000
x1 = INT((cal(8)*(b6*b6/4096))/2048)
x2 = INT(cal(2)*b6/2048)
x3 = x1 + x2
b3 = INT(((cal(1)*4+x3)*2^oss +2)/4)
x1 = INT(cal(3)*b6/8192)
x2 = INT((cal(7)*(b6*b6/4096))/65536)
x3 = INT(((x1+x2)+2)/4)
b4 = INT(cal(4)*x3/32768+cal(4))
b7 = INT((UP - b3)*(50000/2^oss))
p = INT((b7*2)/b4)
x1 = INT(INT(p/256)*INT(p/256))
x1 = INT((x1*3038)/65536)
x2 = INT((-7357*p)/65536)
pressure = INT(p+(x1 + x2 + 3791)/16)
END FUNCTION
FUNCTION Psl(p, alt)
'given local pressure and altitude, returns pressure at sea level
Psl= p/(1- alt/44330.77)^5.25588
END FUNCTION
FUNCTION myAlt(p, p0)
' given local pressure (p) and pressure at sea level (p0)
' returns altitude in metres
myAlt = 44330.77*(1-(p/p0)^0.190263)
END FUNCTION
SUB readhumidity
DHT22 DHT22pin, TEMP, HUMID ' dump stale reading
PAUSE 2000 ' time for the sensor to complete next read
DHT22 DHT22pin, TEMP, HUMID ' this reading is only 2 seconds old
'PRINT TIME$;" Temperature: " STR$(TEMP,3,1);" Humidity: " STR$(HUMID,3,1)
END SUB
It prints the readings every 10 seconds but in real life, every 5 minutes is more realistic.
All you need to do is change the PRINT to PRINT #2
Bizzie
Posted: 04:02pm 09 Feb 2016
TassyJim - Is there much variation in the quality of DHT22's?
There seems to be quite a range of prices on the net. You mentioned HoneyWell should I try the buy these or some no brand name ones?
Rob White
Posted: 06:00pm 09 Feb 2016
The Honeywell sensors are not the same as DHT22's.
They have analog outputs and you have to do the maths to correct for temperature.
They worked well for a couple of years but then gave strange outputs.
When support for the DHT22 was added to MMBasic, I was quick to convert. I haven't been running DHT22's long enough to know how long they last in real life situations.
I purchase cheap ones and carry a few spares.
Bizzie
Posted: 06:11pm 09 Feb 2016
Thanks Jim,
My brother and I were only talking about measuring RH this morning. The window each day for spraying crops is getting less each day as the last rainfall dries out. I will hook a sensor to an MM and take it for a drive on the spray rig and then compare with local static data.
Thanks again.
Rob White
lew247
Posted: 01:21am 13 Feb 2016
TassyJim I don't suppose you know if that code would work with the BME280 sensor?
Posted: 01:24pm 13 Feb 2016
  lew247 said   TassyJim I don't suppose you know if that code would work with the BME280 sensor?
After a quick look at the datasheet, I would say that they are very different.
The data sheet does have plenty of information and is written in good English so should be relatively easy to follow.
lew247
Posted: 06:42am 14 Feb 2016
I did try reading and digesting the data sheet
Yes its in extremely good English, but for a newbie like me it might as well be written in japanese
I know nothing about registers or how to write bits of registers and so on, or what a data burst it, or 20-bit format
Unfortunately I don't even know what a signed 32 bit integer is even though I tried researching it on Google
Posted: 10:48am 14 Feb 2016
I have ordered a BME280 to play with.
It will take 3 to 4 weeks to arrive and hopefully by then I will have a working computer again.
If all that works out OK, I might have time to do the code before I go on holidays in April.
Code for the BMP085 and DHT22 is available now if you want something to start experimenting with.
