Local Time 00:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with LCD screen
Benzol
Posted: 12:35am 06 Feb 2016
Hi All
I have put together the micromite LCD backpack from Silicon Chip but can't initialise the screen.
micri is working OK, I have tested that with print commands but get the following;
OPTION LCDPANEL ILI9341, L, 2, 23, 6
Error: Unrecognised option
Any tips?
Posted: 01:18am 06 Feb 2016
Do you need newer firmware? What is it (MM.VER) now?
Benzol
Posted: 01:37am 06 Feb 2016
Hi John
thank you for that, I had put in an older micromite V4.6. All works ok now with V5.1.
Much appreciated.
David B
