Local Time 00:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Manual Bug, Str$(Var) vs Str$(funct)
twofingers
Posted: 08:19am 04 Feb 2016
@Geoff
regarding the description in MMBasic Manual Ver 5.1 (eg p54):
DIM a, b$, nbr(100), str$(20)
DIM a(5,5,5), b(1000)
DIM str$(200) LENGTH 20
DIM STRING str(200) LENGTH 20
This shows IMHO a wrong and misleading use of the (array) variable name STR$(). STR$() is a reserved word, a MMBasic function and I fear it could confuse some beginners. This only applies to the manual!
Proof:
Dim Str$(1)=("TEST","BEST")
Print Str$(1)
Michael
Edited by twofingers 2016-02-05
Posted: 11:50am 04 Feb 2016
Thanks Michael, well spotted. I will update the manual for the next release.
