Local Time 00:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite issue
larny
Posted: 08:56pm 01 Feb 2016
I wrote the programme below in order to test the Maximite interface hardware that I designed & built.
It is intended to light LEDs in sequence - LED1 for 3 seconds, then LED1 goes off & LED2 lights, etc.
But, when I ran the programme, all LEDs remained dark. So I removed the interface & connected my DMM to one of the outputs. But the voltage remains at 0 when the appropriate output is supposed to be high.
I can't see anything wrong with the programme.
I ran the datalog.bas programme. It detects & displays the voltage at each of the pins 1 ~ 10. So I don't think there is anything wrong with the Maximite.
Any assistance will be appreciated.
100 FOR i = 1 TO 20 : SETPIN i, DOUT : NEXT i 'DOUT or 8 for digital outputs
110 'Pins 1 ~ 20 digital outputs
120 PRINT "Start" : PRINT
130 For i=1 to 20
140 PIN(i)=1
150 PRINT i,
160 Pause 3000
170 PIN(i)=0
180 NEXT i
190 PRINT "Stop"
200 end
Posted: 09:05pm 01 Feb 2016
I don't think you can use the setpin command in a loop like that, can you?
IE: You have to define your setpin commands separately, one after another.
Posted: 09:19pm 01 Feb 2016
What version of MMBasic are you using?
Line numbers suggests an early version.
DOUT was only introduced in later versions so try
100 FOR i = 1 TO 20 : SETPIN i, 8 : NEXT i 'DOUT or 8 for digital outputs
larny
Posted: 11:34pm 01 Feb 2016
  TassyJim said   What version of MMBasic are you using?
Thanks Jim,
That worked. I have MM Version 2.7B. I have not used the MM for about 2 years.
Thanks for the responses.
Len
twofingers
Posted: 01:40am 02 Feb 2016
Hi Len,
  Quote   I have MM Version 2.7B.
I strongly recommend the latest MMBasic version (4.5). It's very easy to update.
Michael
larny
Posted: 12:36pm 02 Feb 2016
  twofingers said   Hi Len,
Michael
Thanks Michael,
I have downloaded the 4.5 version. I'll install it shortly.
Regards, Len
