Local Time 00:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Text orientation not working.
Bizzie
Posted: 06:28pm 31 Jan 2016
Hi all,
Can anyone confirm if panel orientation is working with V5.1 plus on a CGMicroboard2.
Here is my tests :-
> OPTION LIST
OPTION LCDPANEL ILI9341, LANDSCAPE, 21, 22, 23
OPTION TOUCH 18, 14
OPTION SDCARD 49
> TEXT 50,50,"TEST"
> OPTION LCDPANEL ILI9341,P,21,22,23
Restart the Micromite+
> Micromite Plus MMBasic Ver 5.1
Copyright 2011-2016 Geoff Graham
> OPTION LIST
OPTION TOUCH 18, 14
OPTION SDCARD 49
> TEXT 50,50,"TEST"
> OPTION LCDPANEL ILI9341,RL,21,22,23
> OPTION LIST
OPTION TOUCH 18, 14
OPTION SDCARD 49
> TEXT 50,50,"TEST"
TEXT 50,50,"TEST" always displays the same way.
Rob White
Posted: 07:01pm 31 Jan 2016
Ry OPTION LCDPANEL DISABLE befroe setting the new configuration
Bizzie
Posted: 08:28pm 31 Jan 2016
Thanks Jim,
Another case of not reading the manual well enough!
Any thoughts (other than obvious - it's busted) on this error:-
> GUI CALIBRATE
Error: Touch hardware failure
I start the calibration and get the above error on release of the SECOND point. That to me says the touch must of worked OK for the first point. The panel was working OK before a rewire.
Rob White
Posted: 10:53pm 31 Jan 2016
This was something that I added in 5.1. Previously the calibration routine did not report an error if the touch controller was not working.
Due to the way that touch works the calibration routine cannot be sure if the reading from the first calibration point is valid or not. But, if the second reading is the same as the first, it knows that something is wrong. Hence the error message on the second touch.
Bizzie
Posted: 12:34am 01 Feb 2016
Thanks Geoff,
I will replace the panel in this project and use it somewhere I do not want to use touch.
Rob White
