Local Time 23:51 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : mm+ and the source code for 470 chip....
plasma
Posted: 03:52pm 24 Jan 2016
i know you need full ( payed) compiler for the 170 chip and mmbasic .
but can i compile with the "open" version for mm+ and the 470 chip?
Posted: 04:37pm 24 Jan 2016
Yes, you can.
Change the optimisation for gcc to -O1 (level 1).
You will also need to go through the source and delete the qualifier __attribute__((mips16)) which is placed in front of some functions. A global search and replace should do it for you.
When the source is compiled with a lower optimisation it might not fit in the available flash and in that case you will have to reduce the amount of flash allocated to the BASIC program. You do this by adjusting the value assigned to PROG_FLASH_SIZE which is defined in Flash.h
GeoffEdited by Geoffg 2016-01-26
Posted: 11:18pm 24 Jan 2016
You might be able to use gcc and even keep the attributes.
Not having the (MMBasic) source I've not tried it.
JohnL
Posted: 11:43pm 24 Jan 2016
  Quote  You might be able to use gcc and even keep the attributes
As I understand GCC MIPS does not compile for PIC32, has issues.
I know of another open source controller/language platform that are not supporting PIC32 because they can't compile with GCC and they don't want to use crappy and costly microchip compiler with optimization.
Chris Roper
Posted: 11:58pm 24 Jan 2016
You can use GCC for the PIC32/MIPS, that is what ChipKit uses.
  JohnL said  As I understand GCC MIPS does not compile for PIC32, has issues.
Take a look at this:
A guide to build GCC for MIPS / PIC32
I have not personally tried it yet but his step by step guide to getting it up and running on Windows, Mac and Linux platforms looks very comprehensive and even covers linker scripts etc.
A very good read even if you don't actually intend to build your own tool chain.
ChrisEdited by Chris Roper 2016-01-26
http://caroper.blogspot.com/
JohnL
Posted: 01:07am 25 Jan 2016
I can't open that link Chris.
Have found reference to that site elsewhere but still can't open it.
Do you know if it is still alive?
I would definitely be interested in a working GCC compiler setup for PIC32.
Apparently the original GCC for MIPS didn't have the startup code and headers for hardware peripherals for PIC32 and possibly some other issues.
Chris Roper
Posted: 01:21am 25 Jan 2016
I did try it and it opened for me, try this one instead:
http://wise-ware.org/wiki/
I also edited the post above to make them both the same.
  JohnL said   Apparently the original GCC for MIPS didn't have the startup code and headers for hardware peripherals for PIC32 and possibly some other issues.
He used NewLib which is an open source version of the Microchip Libraries.
Basically the same Libraries that ChipKit uses.
Getting it all integrated into an IDE would be the next step but so far I am still frying my brain with his excellent description of the cryptic linker script format.
I wish I had read this befor I built my first PIC32 Bootloader and OTA Uploader, it would have saved me hours.Edited by Chris Roper 2016-01-26
Posted: 02:30am 25 Jan 2016
Some more ideas on supporting PIC32 from C:
1. RetroBSD etc
2. Pinguino project
3. Brian Schmalz / maybe AN Other (sorry, it's a long time since I made notes) - I recall a tutorial about patching gcc (the point being that Microchip use gcc to make xc32 etc so MUST by laws release their changes - the hassle being putting it together again I gather)
edit: I think it was Phil Burgess's www.paintyourdragon.com/uc/
Thanks for that wiki, new one for me.
JohnEdited by JohnS 2016-01-26
JohnL
Posted: 02:26pm 25 Jan 2016
http://www.microchip.com/forums/m789980.aspx
Discussion on microchip forum.
If example in post #19 (XC8 version) has any truth then it is outrageous what microchip is/was doing.
Their expensive full version optimized compiler may have nothing more than omitting the crippling stuffing code that is deliberately inserted in the free version ??
If anyone has full XC32 compiler, may be worth having a look at some disassembled code to compare non optimized and optimized.
