Local Time 00:01 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VERSION command?
kiiid
Posted: 12:36am 24 Jan 2016
Is there any way to find out which version of MM+ firmware is running from within the program?
http://rittle.org
Posted: 12:44am 24 Jan 2016
Yup, the read only variable MM.VER
kiiid
Posted: 01:09am 24 Jan 2016
  Geoffg said   Yup, the read only variable MM.VER
Ah... I have missed that one in the docs. Thanks!
http://rittle.org
kiiid
Posted: 05:16am 26 Jan 2016
PRINT MM.VER says 5.01 on my board, not 5.1...
Is that normal?
http://rittle.org
twofingers
Posted: 07:38am 26 Jan 2016
  kiiid said   PRINT MM.VER says 5.01 on my board, not 5.1...
Is that normal?
Yes.
From MM Manual p50
  Quote  The version number of the firmware in the form aa.bbcc where aa is themajor version number, bb is the minor version number and cc is the revision
number (normally zero but A = 01, B = 02, etc).
Michael
EDIT:
BTW.
Is there already a way to do a (soft-)reset? Something like CPU RESTART but with the startup banner.Edited by twofingers 2016-01-27
Posted: 03:14am 27 Jan 2016
  twofingers said  Is there already a way to do a (soft-)reset? Something like CPU RESTART but with the startup banner.
No, not that I can think of. But CPU RESTART does the same thing as cycling the power (except for the banner).
twofingers
Posted: 04:19am 27 Jan 2016
@Geoff,
thanks for clarifying this!
There is also no "unofficial code" for this purpose known? Eg something like a unexpected error which leads to a reset.
Michael
Posted: 04:56am 27 Jan 2016
No, that is trapped on startup and an error message is displayed instead of the banner.
Why is the banner so important?
Posted: 05:07am 27 Jan 2016
Only way i can think of is to connect a pin to MCLR and drive it low. It will cost you a pin, but it will certainly work.
Oh,wait. What about WATCHDOG 1?
Edited by MicroBlocks 2016-01-28
twofingers
Posted: 05:16am 27 Jan 2016
  Geoffg said  Why is the banner so important?
That's nothing I cannot live with. But I would prefer to see the banner after a reset. Makes the status more clearly - for me!
I'm often using more than one MM (different MMBasic versions) at the same time.
Michael
twofingers
Posted: 05:23am 27 Jan 2016
  MicroBlocks said   Only way i can think of is to connect a pin to MCLR and drive it low. It will cost you a pin, but it will certainly work.
"connect a pin to MCLR and drive it low.": that's a HARDreset. I use that often.
"WATCHDOG 1" gives you
  Quote  Watchdog timeout
Processor restarted
Thanks MB.
Michael
Edit
I would prefer a "verbose mode" for the cpu restart command (CPU RESTART V). Edited by twofingers 2016-01-28
