Local Time 23:51 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite LCD Backpack
drkl
Posted: 01:39am 22 Jan 2016
Hello,
I have seen some screenshoots in the description which are illustrations
of using backpack.Where is a the code which generates this graphical objects?
"An engine monitor with six gages. All gauges are updated in real time and respond smoothly to changes.Program created by Peter Mather (matherp) on The Back Shed forum."
I can't found it...
Which operating system runs in backpack, because it is not mentioned.
drkl
Frank N. Furter
Posted: 02:50am 22 Jan 2016
Hi Drkl,
did you search this thread?
You need the "normal" Micromite firmware (now 5.1) for the backpack...
Frank
drkl
Posted: 08:43am 22 Jan 2016
Hello Frank,
Very thank you. I can't find it.
drkl
Posted: 10:12pm 22 Jan 2016
There is nothing special about the code that created the images. They just used the basic drawing commands available in the 28-pin Micromite.
The nautical speedometer was just a demo to create a pretty picture on the screen. Later I will fill it out to be a full program and release the code.
The engine monitor was a slightly modified version of PeterM's demo program:
2016-01-23_080615_PeterMDemo.zip
The menu example is from a "Garage Parking Assistant" which will be described in the March issue of Silicon Chip. It probably will not make sense without you reading the article but the code is attached anyway:
2016-01-23_080736_ParkingAssist.zip
The Micromite in the Backpack is just running MMBasic V5.1 - nothing special.
GeoffEdited by Geoffg 2016-01-24
