Forum Index : Microcontroller and PC projects : GUI Frame refresh
Bizzie
Posted: 03:22pm 19 Jan 2016
Hi All,
Seems like there may be a problem with updating the text on a frame.
I would like to have the time as the text of a frame but the code below does not update the frame.
Micromite Plus MMBasic Ver 4.7 Beta 37
Copyright 2011-2015 Geof
> option list
OPTION DISPLAY 48, 132
OPTION LCDPANEL ILI9341, LANDSCAPE, 21, 22, 23
OPTION TOUCH 18, 14
OPTION SDCARD 49
> list
Option explicit ON
Const pg9Frm = 1
Const pg9Val1 = 2
CLS
GUI FRAME pg9Frm, Time$ + " " + Date$, 0,13,MM.HRes,MM.VRes,RGB(Yellow)
GUI CAPTION pg9Val1, "???",10,70,LB,RGB(Yellow),RGB(Black)
SetTick 1000, PrnTime
Loop
Sub PrnTime
Print DT$()
CtrlVal(pg9Frm) = DT$()
CtrlVal(pg9Val1) = DT$()
End Sub
Function DT$() As string
DT$ = Time$ + " " + Date$
End Function
> run
00:00:36 01-01-2000
00:00:37 01-01-2000
00:00:38 01-01-2000
00:00:39 01-01-2000
00:00:40 01-01-2000
00:00:41 01-01-2000
00:00:42 01-01-2000
Seeing this code does not cause an error it must be OK to do what I want.
Just had a though and added this line :-
Option Error Abort
BUT did not change problem.Edited by Bizzie 2016-01-21
Rob White
Posted: 06:38pm 19 Jan 2016
I think a frame is a static element which wouldn't usually get changed during program execution.
I am not sure if overlapping GUI elements is wise, if fact I am sure that it is NOT wise, but this is one way of getting what you are after.
Option explicit ON
Const pg9Frm = 1
Const pg9Val1 = 2
CLS
GUI FRAME pg9Frm, " ", 0,13,MM.HRes,MM.VRes,RGB(Yellow)
GUI CAPTION pg9Val1, "???",20,20,LB,RGB(Yellow),RGB(Black)
Loop
Sub PrnTime
Print DT$()
End Sub
End Function
All I did was create a blank space in the frame and positioned the caption to fill that space.
You could delete and recreate the frame each second but that is likely to upset any elements that are relying on the frame such as radio buttons.
Posted: 06:46pm 19 Jan 2016
  TassyJim said  I am not sure if overlapping GUI elements is wise, if fact I am sure that it is NOT wise, but this is one way of getting what you are after.
Do you think that includes creating multiple GUI elements but keeping them hidden?
IE: Create all your GUI element after issuing GUI DEFAULT HIDDEN, but then just show the ones you want - see page 23 of advanced manual. In this way, all GUI elements are initially hidden, but technically speaking, they will all overlap - there is no way to avoid it, when you need several screens of GUI controls. However, you are only enabling the ones on that screen vis GUI SHOW.
Do you see any issues there?
...and I digress a little from the thread topic(apologies to OP), but watching any/all threads about GUI at the moment....
Bizzie
Posted: 06:50pm 19 Jan 2016
I would like to put the time in the frame to save some space on the 2.4" screens.
If it was not allowed I would assume it would generate an error.
Rob White
Posted: 07:23pm 19 Jan 2016
Hidden or disabled should be OK but having two GUI elements trying to detect the same touch is likely to cause grief.
I am not the best person to advise. I have done very little work with the GUI so far and what I have done has been very basic.
Overlapping FRAME and CAPTION seems to work OK but they are but passive elements. Adding input elements is where I would be careful.
Posted: 09:27pm 19 Jan 2016
I never thought of dynamically updating the caption in a frame which is why MMBasic does not check for that. But, it is easy to do. I am just finishing off the final version 5.1 so I will add that in before the close.
On overlapping GUI controls. Yes, you can have them overlapping so long as they are not looking for touch input. So, overlapping hidden controls is fine.
lew247
Posted: 10:40am 18 Jun 2016
I have been playing around with a 7" SSD 1963 LCD a micromite 64 pin and RTC connected, using MMBasic 5.1 and trying to learn the GUI commands
Can someone explain WHY I'm getting the time in the GUI FRAME as well as displayed in the Frame where I actually wanted it?
Remember I'm still extremely new to programming and struggling to get things into my head.
Why does the code "have to have the CONST lines?
Also is it possible to specify a background colour for the frame?
Also is it possible to make the font inside the frame larger?
sorry for so many "weird" questions.
[code]
Option explicit ON
RTC GETTIME
Const abc = 1
Const bcd = 2
CONST cde = 3
CONST def = 4
CLS
GUI FRAME abc,"",50,50,600,350,RGB(RED)
GUI CAPTION bcd,"",325,220,LB,RGB(BLUE)
GUI FRAME cde,"" , 80,80,200,100,RGB(GREEN)
GUI CAPTION def, "Hello Lewis", 120,120,LB,RGB(WHITE)
Loop
Sub PrnTime
CtrlVal(abc) = DT$()
CtrlVal(bcd) = DT$()
End Sub
End Function
[/code]
Edited by lew247 2016-06-19
