Local Time 23:51 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Select Case...
expo
Posted: 08:30pm 15 Jan 2016
Hello all,
I'm having trouble getting my SELECT CASE script to do what I want (maybe it can't do it anyway!).
I have SETPIN 2 (and 3), DOUT
DDD%=64
select case DDD%
case is <32
port(14,5)=DDD%
case is >=32, is <64
pin(2)=1
'ARMDIS%=1 'DEBUG
port(14,5)=(DDD%-32)
case is >=64, is <128
pin(3)=1
pin(2)=1
'ARMDIS%=1 'DEBUG
'OTHER1%=1 'DEBUG
port(14,5)=(DDD%-96)
I'm expecting pins 2 & 3 to go high, but only pin 2 does.
There is a CASE ELSE and END SELECT as well.
The whole script runs without errors, but pin 3 does not go high, as measured by multimeter.
Any thoughts?
EDIT
I am running MMII (170) with 4.06 (4.6b) and have tried a second 'mite.
Thanks,
gregEdited by expo 2016-01-17
MikeO
Posted: 09:14pm 15 Jan 2016
@ expo
try 64 to 128 instead of
Mike
Codenquilts
expo
Posted: 09:22pm 15 Jan 2016
Thanks for the suggestion MikeO but it didn't change the output. Pin 3 still remains off.
greg
Posted: 09:36pm 15 Jan 2016
@expo
First of all, can you inform us which version of MMBasic; and what type of MicroMite?
Also, some things to quickly try:
1> Check Pin(3) LED is ok. Issue a PIN(3)=1 command at the command prompt to ensure electrical connectivity (and hardware) is ok
2> Drop the 'IS' and change to >63 rather than >=64 (in case of firmware bug)
WW
expo
Posted: 10:04pm 15 Jan 2016
Hello WW,
I have tried MikeO's suggested "64 to 127", but there was no change.
I tried your suggestion ">63, <128", but no luck there either.
After the thought process from you both I tried "63<DDD%<128", - no banana either.
I am using MMII (170) 28 pinner, MMBasic 4.6, MMEdit 3.6.4 OS Ver10 (14/9/15).
I have been measuring the output at the MMII pin to avoid spurious extraneous hardware faults.
Can anyone replicate this fault or confirm their system works OK?
greg
expo
Posted: 10:18pm 15 Jan 2016
Hello MikeO and WW (and other watchers),
I think I have an issue wit resetting the pins when DDD% changes downwards.
Stay tuned whilst I work on it .... sometime!
Thanks for your review and the time to respond. I will post any enlightenment.
greg
Posted: 10:19pm 15 Jan 2016
@expo
And have you confirmed that PIN(3)=1 turns on the LED? Or are you saying that you have no LEDs connected and are just using a multimeter?
Is the 28pinner mounted on a breadboard? If so, ensure you measure the voltage directly on the PIC pin 3 and not a position connected to pin 3 via the breadboard. If you're not aware, there have been many posts about issues for people using breadboards, and these always turn out to be 'faulty' (cheap) breadboards.
keep us informed with progress . . . .
WW
Posted: 10:22pm 15 Jan 2016
Yes, maybe a negative ddd% causes the issue!
You're checking for: 64 <= DDD% < 128 and if so, subtracting 96 from it and setting pins to potentially a negative value of DDD%.
Is this the issue maybe??
Posted: 01:52am 16 Jan 2016
Without decoding the program logic the problem could be caused by the fact that the expressions on the CASE line are ORed.
For example,
CASE 1, 2, 3
will be true if the test number is 1 -or- 2 -or- 3
So
Will be always true because the test number will always be greater than 32 -or- less than 64.
I should update the documentation to clarify this.
Posted: 10:24am 16 Jan 2016
DDD% = 64
SELECT CASE DDD%
CASE IS <32
print "<32"
CASE IS <64
print ">=32 and <64"
CASE IS <128
print ">=64 and <128"
CASE ELSE
print ">=128"
END SELECT
There is no need to test for >=32 etc because is the first test for 'less than' passes, the remainder of the SELECT statement is ignored.
Posted: 10:31am 16 Jan 2016
I am curious as to why LED on Pin 3 is not coming on when DDD%=64 (i.e. the posted issue).
The code originally posted should turn it on shouldn't it??
TassyJim: Your code is the 'tidy' solution in terms of coding but can you see why Pin 3 won't go high in expo's code?
WW
Posted: 10:32am 16 Jan 2016
Also - what happens if your use the PORT command with a negative number (as it would be when DDD%=64)?
Does MMBasic generate an error message? OR is the value ignored? Or is it outputted as two's complement?
I am not with a MM at hand at the moment so can not try this one just now.Edited by WhiteWizzard 2016-01-17
Posted: 10:46am 16 Jan 2016
The line
will be the one executed when DDD% = 64 because as Geoff pointed out, the comma is an OR not AND
This sets PIN 2 high
The CASE with PIN 2 and PIN 3 high never gets acted on because of the line above getting first choice.
Posted: 11:11am 16 Jan 2016
Yep - silly me
expo
Posted: 12:06pm 16 Jan 2016
Hello all,
CASE = 64 does turn on pins 2 & 3. Any other combination of <, >, <=, etc fails because as Geoff has clarified they are -OR-'d.
In the short term I will abandon use of SELECT CASE because it overly complicates my logic (and me!).
PORT(14,5)=DDD% works well, so I will work around the higher numbers another way.
Thanks to all for your efforts.
greg
