Forum Index : Microcontroller and PC projects : Error Forum Login with MS Edge
| atmega8 Guru Joined: 19/11/2013 Location: GermanyPosts: 738 |
Hi, when trying to logon with edge 25.10586.0.0 from WIN 10 i alwas get the following Message: 500 - Internal server error. No Problem with Firefox ! |
MicroBlocks![]() Guru Joined: 12/05/2012 Location: ThailandPosts: 2209 |
Same version here. Have been using edge since it came out, never had a problem with this site. Only thing i did was switching of Adobe Flash player in Advanced settings, but i doubt that would be it. Microblocks. Build with logic. |
| Chris Roper Senior Member Joined: 19/05/2015 Location: South AfricaPosts: 280 |
I get that error in Chrome on win7 if I have an VPN or encrypted session running. I just assumed it was a routing issue as my VPN terminates in the UK. Turning off the VPN solves the problem. Have a look and see if win10/Edge is routing via a Proxy or Encrypting in any way. Cheers Chris http://caroper.blogspot.com/ |
| BobD Guru Joined: 07/12/2011 Location: AustraliaPosts: 935 |
I had this problem for a short while (15 minutes) about 7 or 8 hours back. I assumed there was a problem with the site. I was using IE11 on Win 8.1. |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5198 |
Buggered if I know. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
