Local Time 23:27 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Old Bug or New?
vegipete
Posted: 07:04pm 20 Dec 2015
I'm trying to pass a single bracket as a string to a function and am getting an error: (This is running on an 'MX470.)
> LIST
If TEST("(") Then
Print "Bracket"
Else
Print "Something else"
EndIf
End
Function TEST(S$) As INTEGER
If S$ = "(" Then
TEST = 1
Else
TEST = 0
EndIf
End Function
> RUN
[1] If TEST("(") Then
Error: Expected closing bracket
> ? MM.VER
4.07
Is this fixed in newer versions of the MM firmware? Or am I doing something rather wrong?
Note: if I change the "(" to a different character, such as "A", the program runs as expected.
Thanks.Edited by vegipete 2015-12-22
vegipete
Posted: 07:08pm 20 Dec 2015
I see that ")" doesn't work either.
Posted: 08:06pm 20 Dec 2015
just tested your code using an MX170 running the latest 5.0 firmware and the observed behaviour is present.
some interesting variants:
[2] If TEST("tan(45") Then
but 'If TEST("tan(45)") Then' produces the output 'Something else'
rob :-)
Edited by robert.rozee 2015-12-22
ajkw
Posted: 09:41pm 20 Dec 2015
This seems to work ok.
MM170 Ver 5
Cheers,
Anthony
a$ = "("
If TEST(a$) Then
Print "Bracket"
Else
EndIf
End
If S$ = "(" Then
TEST = 1
Else
TEST = 0
EndIf
End Function
Posted: 10:44pm 20 Dec 2015
ouch, that looks like a parser problem in the interpreter.
Posted: 11:35pm 20 Dec 2015
Yes, that does look like a bug and I can guess what is causing it. I will investigate and report back.
Posted: 03:34am 21 Dec 2015
It is a bug and it will be fixed in the next release (due in mid January).
