Local Time 23:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Print to COM1 without cr and lf
rogersan
Posted: 12:06am 25 Nov 2015
I am trying to send 3 characters from COM1 without carriage return and line feed.
I tried putting a semicolon at the end of the print string, to suppress the CR and LF, but it is not working. Instead of 3 characters being sent out on COM1, I get 6. The extra characters are ; and CR and LF.
Tstr$=chr$(85)+chr$(2)+chr$(160)+";"
Open "com1:9600" as #5
Print #5,Tstr$
Does anyone know how to make this work?
twofingers
Posted: 12:10am 25 Nov 2015
I would try this
Print #5,Tstr$;
Michael
Posted: 12:12am 25 Nov 2015
Agreed. Semicolon suppresses the CR and LF on any print command.
EDIT: As you have probably gathered by now, the semicolon has to be part of the command syntax, not a byte of the actual message as in your example. Edited by Grogster 2015-11-26
rogersan
Posted: 08:44am 25 Nov 2015
Thanks very much, now only 3 characters are going out to the Texas Instrumements TMP107 temperature sensor, and I can see a two character reply.
However the INPUT statement is not getting the data. I tried
Indat$=INPUT(10,#5)
LCD 1,1,Indat$
And just get a blank line on the LCD display. LOC says there are five characters in the buffer. I should see "U" as the first character in the receive buffer, as the characters sent are all received ie. Chr$(85) is "U".
I did have to put a delay before the INPUT, otherwise LOC said there were 0 characters in the receive buffer.
Perhaps the receive buffer is too slow to get the data, any suggestions.
rogersan
Posted: 09:03am 25 Nov 2015
Sorry that line should be
Indat$=INPUT$(10,#5)
Posted: 09:04am 25 Nov 2015
Put this:
DO WHILE LOC(#5)<5:LOOP
before the input statement
Edited by matherp 2015-11-26
