Local Time 23:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS18B20 Temp sensor & MM Basic
Hatrick
Posted: 03:19am 17 Nov 2015
One for Geoff:
First, thanks for producing the Basic interpreter for the Micromite. This has stirred my interest after nearly 40 years from first learning Basic.
I understand that the DS18B20 temperature sensor takes 200mS to measure the value, and during this time the processor will ignore other interrupts.
My question is: during this measurement period, is the digital input count feature (ie, SETPIN (n) CIN, FIN)affected? Will it miss counting pulses during this period?
Gerry
Posted: 06:58am 17 Nov 2015
Hi Gerry,
Just out of interest, are you aware that there is a START command which simply triggers the 'conversion'. Whilst the DS18B20 is doing its thing, the MM can continue doing other stuff (including interrupts). Then simply perform a 'read'; if more than 200mS has passed since the START, then the data will be immediately returned, otherwise the 'balance' of time will need to expire first before the data is returned.
Hope this helps . . . .
WW
Posted: 11:27am 17 Nov 2015
Gerry,
Yes, the count input will continue to count. In fact it is the only exception to the "freeze" that occurs while the temperature reading is made.
As WW suggested, you can use TEMPR START to start the conversion and do other things while it is progressing. However, if you are just counting it is not really necessary.
Hatrick
Posted: 01:57pm 17 Nov 2015
Thanks for that, guys. That gives me some ideas as to where I will plant the DS18B20 command in the code.
And I might tinker with that START command as well - wasn't aware of that one!
rgds
gerry
