Local Time 23:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Unexpected text error
Bizzie
Posted: 06:15pm 05 Nov 2015
I am trying to write a small function which will tell me if a particular character is present in a string. The function is to return the position of the first occurrence or 0 if NOT present.
I am getting the following error "Error: Unexpected text"!
Can someone shed some light on what I am doing wrong please.
list
Test$ = ">06-11-2015~15:09:21,367,396,366,346,0,321,<"
Print contains(Test$,">")
Function Contains(ThisStr$,Char$)
Local i
For i = 1 To Len(ThisStr$)
If Mid$(ThisStr$,i,1) = Char$ Then Return i
Next
Return 0
End Function
> ? mm.ver
4.07
> run
[12] If Mid$(ThisStr$,i,1) = Char$ Then Return i
Rob White
Posted: 06:28pm 05 Nov 2015
from the manual:
[code]
INSTR( [start-position,] stringsearched$, string-pattern$ )
[/code]
Returns the position at which 'string-pattern$' occurs in 'string-searched$', beginning at 'start-position'.
A function needs its return value set before exiting it.
[code]
Local i
Contains = 0
Contains = i
EXIT FOR
Endif
Next
End Function
[/code]
Edited by MicroBlocks 2015-11-07
Justplayin
Posted: 06:58pm 05 Nov 2015
  Bizzie said   I am trying to write a small function which will tell me if a particular character is present in a string. The function is to return the position of the first occurrence or 0 if NOT present.
Why not just use INSTR function? It does exactly what you want and it's already part of MMBASIC.
Print INSTR(Test$, ">")
Print INSTR(Test$, "<")
Print INSTR(Test$, "X")
This will output:
1
44
0
--Curtis
Bizzie
Posted: 07:35pm 05 Nov 2015
Thanks Microblocks and Justplayin, another case of "not seeing the wood for the trees" or something.
I would still like to know what is causing the error (bug?)
Rob White
Justplayin
Posted: 07:47pm 05 Nov 2015
The problem with your original code is the incorrect usage of the RETURN command. RETURN is used with GOSUB and does not "return" any value. For a function to return a value you must assign your return value to the function name. That is what is happening with MicroBlocks example. contains = i will cause the function to return the value of i.
--Curtis
Bizzie
Posted: 07:52pm 05 Nov 2015
Thanks Curtis,
Will try to remember that for when ever I need to use a function in the future.
Rob White
