Local Time 23:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uploading a text file using teraterm
drkl
Posted: 08:23pm 02 Nov 2015
I made a datalogger program using Micromite 4.7. I'd like to upload the data to a PC
using Teraterm, and generate a file using console.
I know the the Hyperterminal for Windows program solves this problem,
but I want to use Teraterm or MMedit.
Can anybody help me?
drkl
Posted: 08:43pm 02 Nov 2015
In Teraterm,
go to File/Log...
and select a file name to log to.
In MMEdit,
Open a Chat window,
Make sure you are in ASCII mode and not VT100.
Select Options/Start Capture.
In MMEdit you can also put a timestamp at the start of each line.
This can be useful for long timme logging
Posted: 08:44pm 02 Nov 2015
This may not be exactly what you are after, but in TT, click FILE menu, then LOG...
Select a filename for your data, and click SAVE. Make sure that APPEND and PLAIN TEXT are ticked - the other boxes can remain unticked.
This will open a file on the PC, and capture anything sent to TT from the MM.
Now, start your data transfer via the console, and TT will capture all that to the log file.
When done, click the TT LOG window which has opened when you clicked SAVE, and then click on CLOSE. This will close the file.
The data moved across from the MM via the console to the TT window, should now be saved in the log file.
EDIT: Jim beat me!
Edited by Grogster 2015-11-04
drkl
Posted: 12:55am 03 Nov 2015
I apologize. Before asking, I would have to look at the manuals.
Next time I do this.
Thank You again
drkl
