Local Time 23:13 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : print statement with only cr
drkl
Posted: 09:12am 02 Nov 2015
Hello, is there any possibility always overwrite a number in place?
I hate the scrolling lines...
drkl
Posted: 09:17am 02 Nov 2015
Sure put highly depended on what you are using.
Which version of MMBasic and which of the Maximite/Color Maximite/Micromite is it.
drkl
Posted: 09:46am 02 Nov 2015
Sorry, I forgot: Micromite version 4.7
drkl
Posted: 09:51am 02 Nov 2015
It will also help to know what sort of display (or terminal program) you are using.
If a PC, you can use VT100 commands to position the text wherever you want it.
eg
PRINT CHR$(27)+"[1;1H",TIME$
will print the time at row 1, column 1
If a TFT display, you use different commands.
Posted: 10:48am 02 Nov 2015
If you pad to a consistent length you can use
print chr$(13);x$;
or
print chr$(13)+x$;
where x$ is the padded string.
The idea is CR but not LF
JohnEdited by JohnS 2015-11-03
drkl
Posted: 12:17pm 02 Nov 2015
Many thanks, both solutions are good, I tested with Teraterm.
drkl
