Local Time 23:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Some things I’d like to be able to do...
CircuitGizmos
Posted: 09:53am 29 Oct 2015
I'd like to be able to put the LCD/touch/sd options into code. If option had a pass/fail return value then something like this might work:
LCDresult = OPTION LCDPANEL ILI9341, L, 21, 22, 23
IF LCDresult = 1 THEN
' Option setting worked
CPU RESTART
ELSEIF LCDresult = 2 THEN
' Option already set exactly like you want
ELSEIF LCDresult = 3 THEN
' Option setting failed
ENDIF
TOUCHresult = OPTION LCDPANEL ILI9341, L, 21, 22, 23
IF TOUCHresult = 1 THEN
CPU RESTART
ELSEIF TOUCHresult= 2 THEN
ELSEIF TOUCHresult = 3 THEN
ENDIF
IF TOUCHresult = 3 OR LCDresult = 3 THEN
' Failure
' Run fail LED blink routine
ENDIF
CALresult = GUI ISCALIBRATED
IF CALresult = FALSE THEN
' Not calibrated
GUI CALIBRATE
GUI TEST TOUCH ' With a random off-centered EXIT square
CLS
GUI TEST LCDPANEL 5 ' Run for 5 seconds
ENDIF
Edited by CircuitGizmos 2015-10-30
Zonker
Posted: 04:53pm 29 Oct 2015
Humm.. From what I gather here, are you trying to automate the LCD setup process..? Might save some time when producing new units to set on the shelf..!
But.. I wonder if somehow, you could write a tera-term macro file to send down the commands to the "freshly flashed" MM board and have the PCB execute them one line at a time... That way, no firmware changes are needed...
The TT script kings have already posted a macro to reset the comm port and reconnect the MM USB... I am sure you can command TT to send out strings of ASCII characters... One ting I'm not sure about.. Can you type in somthing at the command line that makes the MM do a system restart..?
I'm sure others will chime in on this one CG..!
Posted: 06:06pm 29 Oct 2015
Setup ONE chip with the settings you want for LCD and SD card etc - perhaps even a first running program, then read the entire chip into a HEX file with IPE.
This HEX file will now contain the MMBASIC firmware, all your set options for LCD, SD card etc, AND your program code if you have elected to have it there.
That is assuming that you want to program lots of MM's with the same settings, and don't want to have to do each and every one separately.
This might not be exactly what you are wanting to do.
Zonker
Posted: 07:12pm 29 Oct 2015
Humm... I though each LCD screen touch panel would be a little different than any other LCD display, so just replicating the flash image into a group of units might cause problems with touch cal being off... (maybe not)...
CircuitGizmos
Posted: 05:21am 30 Oct 2015
  Zonker said   Humm... I though each LCD screen touch panel would be a little different than any other LCD display, so just replicating the flash image into a group of units might cause problems with touch cal being off... (maybe not)...
Yes I already know the one-hex-file approach, but I don't know how the calibration settings would be affected.
I was also hoping to keep all of the "information" in the basic file, rather than having to manually connect, type something, reset (disconnect), reconnect, and repeat and only after that run the basic file.
kiiid
Posted: 06:04am 30 Oct 2015
This is quite the same as my question here
You can see Geoff's answer to it as well.
Edited by kiiid 2015-10-31
http://rittle.org
