Local Time 23:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Number of Days between two dates?
Justplayin
Posted: 04:31pm 27 Oct 2015
I'm going to be really lazy about this one...
Anyone have a MMBASIC code segment that calculates the number of days between two dates? I'm working on a count down timer between two dates and my mind keeps giving me a busy signal for this.
Thanks,
Curtis
Posted: 04:52pm 27 Oct 2015
I posted this code here a couple of years ago.
I have made a small change to make it work on MMBasic 4.7.
The code was produced well before MMBasic had integers so it looks strange.
(most of my code looks strange!)
dim jdi as integer
Newdate$= date$
mainloop:
DOW (Newdate$, weekday, dy$) ' returns day of week as number and string
splitdate (Newdate$, day, month, year)
toJD (day, month, year, jd) ' returns Julien Day Number
jdi = jd ' convert to iteger for printing
print Newdate$;" "weekday;" ";dy$ ;" - JD number: ";str$(jdi)
input "New Date: ", Newdate$
if Newdate$<>"" then goto mainloop
end
' given date as string, returns day, month, year
sub splitdate (currentdate$, d, m, y)
d= val(mid$(currentdate$,1,2))
m= val(mid$(currentdate$,4,2))
y= val(mid$(currentdate$,7,4))
end sub
'given day, month, year
'dayz=days since 1/1/1900 - agrees with Excel after 1/3/1900
sub toMSday (d, m, y, dayz, dayofyear)
dayofyear= d+int((m-1)*30.57+0.5)
if m>2 then
dayofyear= dayofyear-1
if (y mod 4)>0 then dayofyear= dayofyear-1
endif
dayz= int((y-1900)*365.25-0.25)+dayofyear+1
end sub
' given date as string, returns day of week as number and string
sub DOW (currentdate$,weekday, dy$)
local d, m, y, dayz
weekday= abs((dayz-1) mod 7)
dy$=mid$("SunMonTueWedThuFriSatSun",weekday*3+1,3)
end sub
' input day, month, year - returns julien day number
sub toJD ( d, m, y, jd)
ff = fix((m-14)/12)
jd = fix((1461*(y+4800+ff))/4)+fix((367*(m-2-12*ff))/12)-fix((3*( fix(y+4900+ff)/100))/4)+d-32075
end sub
'input julien day - returns day, month, year
sub fromJD (jd, d, m, y)
local l, n, i, j
l = jd + 68569
n = fix(( 4 * l ) / 146097)
l = l - fix(( 146097 * n + 3 ) / 4)
i = fix(( 4000 * ( l + 1 ) ) / 1461001)
l = l - fix(( 1461 * i ) / 4 )+ 31
j = fix(( 80 * l ) / 2447)
d = l - fix(( 2447 * j ) / 80)
l = fix(j / 11)
m = j + 2 - ( 12 * l )
y = 100 * ( n - 49 ) + i + l
end sub
You will need to convert to JD and back after doing the maths.
Justplayin
Posted: 08:25am 28 Oct 2015
Thanks Jim! I guess I'm just been spoiled by how simple this is to do in Liberty BASIC with it's built-in date functions.
--Curtis
Posted: 11:57am 28 Oct 2015
  Justplayin said   Thanks Jim! I guess I'm just been spoiled by how simple this is to do in Liberty BASIC with it's built-in date functions.
--Curtis
Except that Liberty Basic wants the date in that strange 'American' order of month,day,year and I have to keep putting it into the correct order for this part of the world.
In LB, the file date format depends on the users regional settings so it can be trick to get it correct. I have to resort to the API.
I am glad that Geoff got things right!
Justplayin
Posted: 12:48pm 28 Oct 2015
  TassyJim said  Except that Liberty Basic wants the date in that strange 'American' order of month,day,year and I have to keep putting it into the correct order for this part of the world.
Now you did it... I promised myself I wouldn't get into a date orders controversy.
What do mean? Month/Day/Year is the perfect order! All other date formats should be universally banned!
But seriously, I okay with the European format, but as an American I would much rather use MM/DD/YY. I always thought Liberty BASIC supported the other format, but I see now it's really just variations of the MM/DD/YY theme.
--Curtis
Okay guys... This is all in fun, let's not start another flaming Date Debate again.
CircuitGizmos
Posted: 05:53am 29 Oct 2015
*cough* ISO8601 *cough*
Chris Roper
Posted: 06:12am 29 Oct 2015
  CircuitGizmos said   *cough* ISO8601 *cough*
That is about as dangerous as mentioning SI Units.
http://caroper.blogspot.com/
twofingers
Posted: 06:21am 29 Oct 2015
BTW.
jim did far more useful date conversion routines.
