Local Time 23:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 28 pin Micromite kit
CircuitGizmos
Posted: 11:43am 23 Oct 2015
http://circuitgizmos.com/gizmo-store/#!/CGMICROKIT-Micromite-Kit/p/56099157/category=14171441
Zonker
Posted: 12:32pm 23 Oct 2015
Nice CG..!
Another excellent PCB starter kit with a good standard interface..
I like the sea-o-holes... Just drop in an RTC module or display and your in business..
Nice job..!
isochronic
Posted: 02:25pm 23 Oct 2015
Interesting !
How does it connect ? I can't see any usb connection, does it require a usb-serial converter / or ttl terminal of some sort ?
Posted: 02:54pm 23 Oct 2015
  chronic said   Interesting !
The console Rx Tx lines are brought out to a header but it does need a USB-TTL adapter.
A useful experimenters board.
CircuitGizmos
Posted: 04:05pm 23 Oct 2015
Meant to be easy to assemble, through hole, and not require any drivers. You have to connect using a TTL/USB device.
