Local Time 23:05 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I2C Problem - Lines being split
Bizzie
Posted: 02:15pm 20 Oct 2015
Hi All,
Why is there a problem in this simple test code?
Here is the code for the "Tramsmit" end :-
> list
I2C Open 100,100
A = A + 1
InBuff$ = ">" + Str$(A) + ",11,12,13,14,15,16<"
I2C Write &H26,0,Len(inbuff$),InBuff$
Print InBuff$
Pause 1500
Loop
> ? mm.ver
4.05
> run
>1,11,12,13,14,15,16<
>2,11,12,13,14,15,16<
>3,11,12,13,14,15,16<
>4,11,12,13,14,15,16<
>5,11,12,13,14,15,16<
>6,11,12,13,14,15,16<
And for the receive :-
> list
' Bar graph display.
' Data from I2C
I2C SLAVE Open &H26,0,0,WriteD,ReadD
WatchDog 1000
Loop
Sub BarGraf
End Sub
Sub ReadD
I2C Slave Read 70,InBuff$,Recd
Print Recd;"- ";InBuff$
BarGraf
End Sub
Sub WriteD
End Sub
> ? mm.ver
4.07
> run
2- >1
6- ,11,12
13- ,13,14,15,16<
2- >2
5- ,11,1
14- 2,13,14,15,16<
2- >3
6- ,11,12
13- ,13,14,15,16<
2- >4
5- ,11,1
14- 2,13,14,15,16<
2- >5
6- ,11,12
13- ,13,14,15,16<
2- >6
6- ,11,12
13- ,13,14,15,16<
2- >7
5- ,11,1
14- 2,13,14,15,16<
2- >8
6- ,11,12
13- ,13,14,15,16<
Note MM version info ie Maximite on transmit side and MicroMite on receive
Expected output :-
21- >8 ,11,12,13,14,15,16<
Anyone any ideas?
Rob
Rob White
Posted: 03:37pm 20 Oct 2015
You appear to be suffering from the usual problem with serial comms.
The interrupt occurs as soon as the first character is received but it takes time for the rest of the message to arrive.
A simple 'PAUSE 400' at the beginning of your readD sub should solve the problem.
You may ahve to adjust the delay time to suit your data length.
Keep reducing the time until characters are lost the add a suitable time 'to be sure'.
The alternative is to store the incoming data into a buffer until you get to an end of data condition (character count or flag character etc).
Edit: It takes about 100uS for a character at 100k so if you are looking for up to 70 characters, try a delay of 10mS
Edited by TassyJim 2015-10-22
Bizzie
Posted: 05:39pm 20 Oct 2015
Thanks Jim,
As always simple when explained to you!
Rob
Rob White
