Forum Index : Microcontroller and PC projects : Help needed: MM+ FILES fspec$
| WhiteWizzard Guru Joined: 05/04/2013 Location: United KingdomPosts: 2998 |
Hi, Please can anyone with a MM+ setup try the FILES fspec$ command for me.
Whenever I try it I get a '0 directories, 0 files' message displayed. However, the FILES command by itself works fine. I have tried this on an Explore64 module (B36) and a custom setup based on a 64pinner with ILI9341 (touch) and separate SD card socket ((under B37). I am using a 2G Kingston card that saves and loads without fail. But whenever I specify *.*, or *.BAS, or *.BMP, I never see a list of files. Any help would be appreciated. If you can post your setup info and Beta version too it will help track down the issue
Many, many thanks to you all . . . WW |
| Greg Fordyce Senior Member Joined: 16/09/2011 Location: United KingdomPosts: 153 |
Using beta 37 I can't get it to work with the fspec option either. > files
\ <DIR> DEMO <DIR> MMEDIT <DIR> TRASH-~1 11750 CELLII.CSV 696 NAME.BAS 802 NAME2.BAS 5272 PUMPDEMO.BAS 35 RS.CSV 6453 TEST.CSV 7182 TESTER1.BAS 7282 TESTER14.BAS 7536 TESTER2.BAS 7182 TESTER3.BAS 3 directories, 10 files > files "*.*" \ 0 directories, 0 files > files *.* \ 0 directories, 0 files > |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12183 |
Bug confirmed |
Thanks - that solves one of my two issues |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10109 |
Confirmed here too. Smoke makes things work. When the smoke gets out, it stops! |
Thanks folks, it will be fixed in the next beta. Geoff Graham - http://geoffg.net |
