Local Time 22:59 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : FOR NEXT can I have 2 next?
viscomjim
Posted: 06:16am 13 Oct 2015
Is this legitimate...
FOR X = 1 TO 10
GETINFO
IF Z = 0 THEN
STUFF(X) = 0
NEXT X
END IF
STUFF(X)=Z*2
NEXT X
Not concerned about the operations, but can there be 2 nexts in a for next loop based on an if then?
Posted: 06:41am 13 Oct 2015
No you can not.
However in beta 36 there is now a CONTINUE FOR, which i am happy to say is one of my wishes coming true. :)
You would use it like this:
[code]
FOR X = 1 TO 10
GETINFO
IF Z = 0 THEN
STUFF(X) = 0
CONTINUE FOR
END IF
STUFF(X)=Z*2
NEXT X
[/code]
You example could also be done with:
[code]
FOR X = 1 TO 10
GETINFO
IF Z = 0 THEN
STUFF(X) = 0
ELSE
STUFF(X)=Z*2
END IF
NEXT X
[/code]
Which in this particular case would be a better way to do it.
But i guess it was only an example, not a real part of the program.
Edited by MicroBlocks 2015-10-14
viscomjim
Posted: 06:54am 13 Oct 2015
Thanks MB, that make perfect sense. Couldn't see the forest for the trees... What was I thinking?????
