Local Time 22:59 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DIM from query
viscomjim
Posted: 05:44am 13 Oct 2015
Is it possible to query a device and based on the response, set up my DIM statement for an array somewhere other than the beginning of the program?
Example, in my program, I query the device, Once queried, the device returns and says it has 20 objects (lets call them FRANKS) and each object has 1 - 30 things in it (lets call them BEANS). Once I get this information from the device, can I then put in my program...
OPTION BASE 1
GETINFO FRANK, BEANS
DIM OBJECTS(FRANKS, BEANS) <<<<<< this line
DO
STUFF
STUFF
STUFF
LOOP
SUB GETINFO FRANKS, BEANS
STUFF TO GET X
STUFF TO GET Y
STUFF
FRANKS = X
BEANS = Y
END SUB
Or do I have to DIM this in the beginning of the program with the max allowed franks and beans?
Posted: 05:56am 13 Oct 2015
Not a problem the attached is an example out of my sprite demo
' create a simple background to demonstrate that display memory is restored after a sprite is erased
cls rgb(0,89,41)
box 0,200,480,72,1,rgb(123,117,0),rgb(123,117,0)
box 0,0,480,100,1,rgb(123,255,255),rgb(123,255,255)
circle 400,50,30,,,rgb(yellow),rgb(yellow)
pwm 1,1000,50 'set the display backlight
read nsprites%,width%,height% 'read in the sprite data
' Dimension basic variables and the main arrays
DIM i%,j%,k%,l%,xold%,yold%
dim x%(numsprites%),y%(numsprites%),displaydata%(width%*height%/2,numsprites%),sprites%(width%*height%/2,nsprites%)
viscomjim
Posted: 05:59am 13 Oct 2015
Excellent! Thank you Matherp!
