Local Time 11:55 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Interesting chip
kiiid
Posted: 03:22am 05 Oct 2015
SC18IM700 manufactured by NXP.
I luckily came across this one only because I needed exactly this functionality. It can save a whole microcontroller in some cases.
It is an I2C master which is controlled via serial UART channel by text instructions. On top of that it also has a GPIO 8-bit port also available through text commands from the serial port.
I thought this info could be interesting to someone else too.
http://rittle.org
OA47
Posted: 11:49am 05 Oct 2015
Thanks kiiid, a good one to keep in mind.
GM
Chris Roper
Posted: 12:01pm 05 Oct 2015
Any Idea of availability and cost?
http://caroper.blogspot.com/
darthmite
Posted: 12:14pm 05 Oct 2015
I found them in Farnell Europe page.
SC18IM700
And ... Thanks Kiiid , Chip like that is a must have
Cheers.
Chris Roper
Posted: 12:25pm 05 Oct 2015
So that is US$2.20 not a bad price for a 1 off purchase, but if you have a stock of small PICs on hand you could code one for the same functions.
I have been looking for a test project for the next release of Great Cow Basic, maybe I could try and emulate this device and post the hex file here for general use.
a suitable PIC12 or PIC16 will probably be half the price and I could probably make the source portable to run on any PIC you have at hand.
No Promises, but worth a try :)
Chris
