Forum Index : Microcontroller and PC projects : Whats wrong with my GOSUB?
| Bizzie Senior Member Joined: 06/07/2014 Location: AustraliaPosts: 194 |
Hi all, Here is a simple test of ON GOSUB ' Test of GO SUB
Do kb$ = Inkey$ If kb$ <> "" Then Print ">";kb$;"<== Pressed!" On Val(kb$) GoSub Menu1,Menu2,Menu3,Menu4,Menu5,Menu6 Loop Sub Menu1 Print "Menu 1" End Sub Sub Menu2 Print "Menu 2" End Sub Sub Menu3 Print "Menu 3" End Sub Sub Menu4 Print "Menu 4" End Sub Sub Menu5 Print "Menu 5" End Sub Sub Menu6 Print "Menu 6" End Sub Here is two attempted runs > run >1<== Pressed! [6] On Val(kb$) GoSub Menu1,Menu2,Menu3,Menu4,Menu5,Menu6 Error: Cannot find label > run >2<== Pressed! [6] On Val(kb$) GoSub Menu1,Menu2,Menu3,Menu4,Menu5,Menu6 Error: Cannot find label > ? mm.ver 4.05 > I am using a CGCOLORMAX 2 running the above version. What is it that I do not understand? Rob Rob White |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6609 |
' Test of GO SUB DO kb$ = INKEY$ IF kb$ <> "" THEN PRINT ">";kb$;"<== Pressed!" ON VAL(kb$) GOSUB Menu1,Menu2,Menu3,Menu4,Menu5,Menu6 LOOP Menu1: PRINT "Menu 1" RETURN Menu2: PRINT "Menu 2" RETURN Menu3: PRINT "Menu 3" RETURN Menu4: PRINT "Menu 4" RETURN Menu5: PRINT "Menu 5" RETURN Menu6: PRINT "Menu 6" RETURN I would use SELECT CASE rather than ON GOSUB then you can use SUB....END SUB Edit: Select case is not available for MMBasic V4.5 Jim VK7JH MMedit |
Thanks Jim, Yes I would use Select Case too if I could. Don't like labels much! Thanks Rob Rob White |
| BobD Guru Joined: 07/12/2011 Location: AustraliaPosts: 935 |
You could try resolving Val(kb$) before the ON command. [code] Do kb$ = Inkey$ If kb$ <> "" Then Print ">";kb$;"<== Pressed!" kb = val(kb$) On kb GoSub Menu1,Menu2,Menu3,Menu4,Menu5,Menu6 Loop [/code] |
MicroBlocks![]() Guru Joined: 12/05/2012 Location: ThailandPosts: 2209 |
Another possibility. I like to change strings into numbers as quickly as possible because strings are pretty slow in processing. (Not so important here). [code] DO key = ASC(INKEY$) - 48 ' "1" = ascii code 49 IF key = 1 THEN Menu1 ELSE IF key = 2 THEN Menu2 ELSE IF key = 3 THEN Menu3 ELSE IF key = 4 THEN Menu4 ELSE IF key = 5 THEN Menu5 ELSE IF key = 6 THEN Menu6 ELSE 'Illegal key pressed 'Do something with it or ignore ENDIF LOOP [/code] Microblocks. Build with logic. |
| WhiteWizzard Guru Joined: 05/04/2013 Location: United KingdomPosts: 2991 |
@Bizzie Answering your original question - you have no RETURN (hence TassyJim's post sorting this out). I am sure you've managed to sort it all out by now but for completeness here is a listing using SELECT CASE that you referred to:
' Test of GO SUB
Do kb$ = Inkey$ If kb$ <> "" Then Print ">";kb$;"<== Pressed!" kp = ASC(kb$) - 48 ' "1" = ascii code 49 select case kp case 1 Menu1 case 2 Menu2 case 3 Menu3 case 4 Menu4 case 5 Menu5 case 6 Menu6 case else 'Illegal key pressed 'Do something with it or ignore end select Loop Sub Menu1 Print "Menu 1" End Sub Sub Menu2 Print "Menu 2" End Sub Sub Menu3 Print "Menu 3" End Sub Sub Menu4 Print "Menu 4" End Sub Sub Menu5 Print "Menu 5" End Sub Sub Menu6 Print "Menu 6" End Sub WW EDIT: Not sure if v4.05 has the SELECT CASE function |
No. If ...Then .. ELSEIF ... .. ENDIF is the alternative. Jim VK7JH MMedit |
Thanks to all who have responded. All sorted now. Regards Rob Rob White |
