Local Time 11:58 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite variables
helltek
Posted: 10:25am 30 Sep 2015
I'm looking for help. I try to write search routine to find Maxim/Dallas 1-wire devices. When I try to assign Family code, or the Serial number to variable Family(device), it doesn't work. When I try to read Family(1), Family(2), Family(3) I get the last Family code assigned to all of them.
Basically Family(device) is not getting it. How do you populate variable x(i) ???
Greg Fordyce
Posted: 11:02am 30 Sep 2015
Can you post your code?
helltek
Posted: 11:16am 30 Sep 2015
'SUBROUTINES
'One Wire Search
'Search the 1-wire bus and discover attached devices
one_wire_search:
devices = 0
discover_device:
discrepancy = 0
last_bit=0
Family(devices)=0
Family_nbr=0
SerNo_nbr=0
CRC_nbr=0
ROMcode_nbr=0
ONEWIRE RESET (one_wire_pin)
if MM.ONEWIRE = 0 then goto one_wire_error1 'MM.ONEWIRE returns 0 if no presence pulse
ONEWIRE WRITE (15), 0, 1, &hF0 'pin, flag, length, data [, data…] (F0h = Search)
count64bits:
for i = 1 to 64
ONEWIRE READ (15), 4, 1, a 'read 1 bit of 1-wire devices
ONEWIRE READ (15), 4, 1, b 'read complement of 1 bit
If a + b = 2 then goto one_wire_error2 'no devices responded
if a + b = 0 and last_discrepancy=i then a=1
if a + b = 0 and last_discrepancy>i then a=last_bit
if a + b = 0 and last_discrepancy<i then a=0
if a + b = 0 then last_discrepancy = i: discrepancy = discrepancy + 1: last_bit=a
ONEWIRE WRITE (15), 4, 1, a 'write bit to continue search
print bin$(a,1);
if i>0 and i<9 then Family_nbr=Family_nbr+(a<<i-1): Family(devices+1)=Family_nbr
if i>8 and i<57 then SerNo_nbr=SerNo_nbr+(a<<(i-9)): SerNo(devices+1)=SerNo_nbr
if i>56 and i<65 then CRC_nbr=CRC_nbr+(a<<(i-57)): CRC(devices+1)=CRC_nbr
ROMcode_nbr=ROMcode_nbr+(a<<i-1): ROMcode(devices+1)=ROMcode_nbr
next i
devices = devices + 1
print
print "last_discrepancy =" last_discrepancy
print "discrepancy =" discrepancy
print "last_bit =" last_bit
print "devices =" devices
print "Family"(devices)" = " hex$(Family(devices), 2)"h"
print "SerNo"(devices)" = " hex$(SerNo(devices), 12)"h"
print "CRC"(devices)" = " hex$(CRC(devices), 2)"h"
print "ROMcode"(devices)" = "hex$(ROMcode(devices), 8)"h"
print
print "Device CRC:"
'check crc
c1=0 'clear crc "c1" prior sending first byte
b1=ROMcode(devices) 'byte or bytes to calculate crc on
n=8 'the number of bytes sent (since leading zeros are not in the integer)
gosub crc_8
if c1<>0 then i=devices: gosub one_wire_error3
print
print "-------------------"
print
if discrepancy <> 0 then goto discover_device 'search for more devices
one_wire_search_end:
error=0
RETURN
one_wire_error1:
error=1
print: print "Error1 MM.ONEWIRE = 0, Devices not found": print
devices = 0
RETURN
one_wire_error2:
error=2
print: print "Error2 True bit + Complement bit in search" i " do not match": print
RETURN
one_wire_error3:
error=3
print: print "Error3 CRC(device"(i)") does not match": print
RETURN
Chris Roper
Posted: 11:21am 30 Sep 2015
I suspect you need to tell it how many entries in the array:
#define MaxDevices 10
Dim Family(MaxDevices)
Chris
http://caroper.blogspot.com/
helltek
Posted: 01:39pm 30 Sep 2015
I played with the DIM but I'm not getting anywhere. It either doesn't work (assignes the last Family code read to all variables, or I get all kinds of error messages: Variable out of bounds, Variable not declared, etc.
There has to be a way to use variable x(i) in Basic. It worked in GWBasic 25 years ago.
Posted: 02:54pm 30 Sep 2015
maxdevices = 10
DIM Family(maxdevices)
FOR device = 1 TO maxdevices
Family(device)=device*10
NEXT device
PRINT Family(device)
NEXT device
The code you supplied doesn't DIM the array so we can only guess where your problem is.
With MMBasic, you have the choice of starting arrays at zero or one.
See OPTION BASE
helltek
Posted: 05:20pm 30 Sep 2015
This is the actual search routine:
count64bits:
for i = 1 to 64
print bin$(a,1);
next i
In Maxim/Dallas 1-wire datasheet it is READ 2 bits, WRITE 1 bit, do it 64 times for each device, so the loop for i = 1 to 64 discovers one device. The full 64 bit device number is te ROMcode_nbr, Family code is separated into the first 8 bits Family_nbr, 48 bit serial number is in SerNo_nbr and the CRC byte is in CRC_nbr.
That's one device. Now I need to save it in:
ROMcode(devices)
Family(devices)
SerNo(devices)
CRC(devices)
That's the part that doesn't work. I'm unable to assign the Family(devices)=Family_nbr as you see it in the code.
I never had to use DIM in GWBasic, so I don't know how to do it. In GWBasic x(i) was accepted variable. Here in MMBasic it doesn't work. Even if I try the code snippets you provide, I get errors. Variable out of bounds, etc.
helltek
Posted: 06:15pm 30 Sep 2015
Just a note:
I used GWBasic, 8051 Basic, BasicMicro Basic, and variable x(i) worked in all of them. I didn't try Parallax BasicStamp, but I can hook one up and test it.
I think this is a bug in the Micromite and I hope someone found an easy way around, since there is no storage area where I can save discovered devices.
Only the variable "devices" will tell me how many devices are on the 1-wire bus when the search routine ends.
Posted: 07:19pm 30 Sep 2015
You appear to have 4 arrays
Family()
SerNo()
CRC()
ROMcode()
(Unless they are referring to user defined functions)
For each array, you need to declare how big they are.
You use DIM for this.
DIM Family(25) etc.
This will allow for up to 25 elements in the array.
Some versions of basic will automatically create arrays but the size is usually limited to 10 or 11 elements so you will still need to DIM larger arrays.
If you are uncertain about the number of devices, just make the array bigger. Extra elements are not usually a problem.
I don't have any one wire devices here so I couldn't run your full code but seeing it might help.
The code sample I posted does run on V4.5 and V4.7
LIST ALL
maxdevices = 10
Dim Family(maxdevices)
For device = 1 To maxdevices
Next device
Print Family(device)
Next device
> run
10
20
30
40
50
60
70
80
90
100
If I change the loop to read
For device = 1 To maxdevices+1
We get an error
[5] Family(device)=device*10
Error: Array index out of bounds
If you are getting errors "Variable not declared", I assume that you have OPTION EXPLICIT set, but I am only guessing.
helltek
Posted: 08:56pm 30 Sep 2015
I'm really dumb when it comes to understanding code, DIMs, arrays, etc. I can not imagine it in real life, so I have no clue how they are arranged and what they can hold or represent.
For example I have no idea why your example says "device*10". What is it multiplying?
The way the example is, I need to somehow place it around my "for i = 1 to 64" loop because the 64 bits are just one 1-wire device. The number of "devices" are the next devices hooked up to the 1-wire bus. The search routine has to do this 64 bit loops until there is no discrepancy (multiple devices) on the 1-wire bus. Each loop increments the number of discovered "devices", so there would be Family(devices) or in simple example x(i) Family(1), Family(2), Family(3) where the number is a device and the Family is the Family Code of the device let say 28h for DS18B20 thermometer.
Then there is the 48 bit Serial number SerNo(devices) and crc checksum byte CRC(devices).
Posted: 09:07pm 30 Sep 2015
That was just a way of getting a value to put in the array. It has no meaning other than something to show that the array was filled.
Posted: 09:12pm 30 Sep 2015
maxdevices = 10, so the FOR/NEXT loop that starts with 'FOR device=1 to maxdevices' is calculating the values for the array elements and is saving them there.
So, with device=1 at the start of the loop, the line 'Family(device)=device*10' calculates the value for the element in the Family array at position 'device'.
The first time through the loop, 'device' is 1, so: Family(1)=1*10 - this is because device is currently 1, and the value of Family(1) will now be 10.
Next time through the loop, device=2, so: Family(2)=2*10 - Family(2) will equal 20.
Third time: Family(3)=3*10 - Family(3) will equal 30.
...and so on, till it gets to 10, and therefore Family(10) will equal 100.
The 'Print Family(device)' loop just reads back that data, and prints it.
EDIT: Jim beat me to it!!! Edited by Grogster 2015-10-02
Posted: 11:04pm 30 Sep 2015
Easiest to imagine an Array is to think of a cabinet with drawers.
The bottom one is drawer number 0.
Arrays can have dimensions. Lets stay with one dimension for now.
If you define a one dimensional Array with DIM myArray(10) then it will have 11 !! 'drawers'.
Remember computers start counting with 0.
10 is the highest number or 'Upper bound'.
If you don't use a DIM to define an array and you want to write something in it then it is the same as asking someone to put a book in drawer 4. If there is no cabinet with drawers this is impossible. Same here. You ask the program to store a value (book) in a drawer(array element) that is non existent.
This is what causes the error 'Variable not declared'
Now imagine you have a cabinet with 5 drawers and you ask someone to put a book in drawer 6. This is also impossible. The is the cause of error 'Variable out of bounds'
What is important when working with arrays is to make sure they exist and before storing values in it make sure the 'drawer' exists.
It is always best to define the variables you use, this can catch errors.
Include the command OPTION EXPLICIT as the first line of your code.
Creating:
[code]
CONST ARRAYSIZE 10
DIM myArray(ARRAYSIZE)
DIM ArrayIndex = 0
[/code]
Checking:
[code]
if ArrayIndex <= ARRAYSIZE then myArray(ArrayIndex)="Whatever value"
[/code]
used in loops
[code]
for ArrayIndex = 0 to ARRAYSIZE
myArray(ArrayIndex) = 'Some value'
next
[/code]
[code]
ArrayIndex = 0
DO UNTIL ArrayIndex > ARRAYSIZE
'Do some searching/calculations/etc
myArray(ArrayIndex) = "A result"
ArrayIndex = ArrayIndex +1
LOOP
[/code]
Hope this helps.
helltek
Posted: 02:41am 01 Oct 2015
I tried whatever I could think of, but no luck.
For example this code does what happens.
maxdevices = 10
Dim ROMcode%(maxdevices)
Dim SerNo%(maxdevices)
Dim CRC(maxdevices)
for devices = 1 to maxdevices
if devices <= maxdevices then Family(devices)=1
if devices <= maxdevices then Family(devices)=2
next devices
print Family(1)
print Family(2)
print Family(3)
There is no way to asign value (the 1-wire device code) in this loop since the last device is what's printed. There is no Family(1), Family(2), etc. They're all same.
I have no idea why simple x(i) variable can't be created.
Chris Roper
Posted: 02:45am 01 Oct 2015
That is because you are assigning the value 2 to every element of the array.
[code]
if devices <= maxdevices then Family(devices)=1 ' assigns a value of 1
if devices <= maxdevices then Family(devices)=2 ' overwrite with a value of 2
next devices ' increment to next array element and repeat
print Family(1) ' prints 2
print Family(2) ' prints 2
print Family(3) ' prints 2
[/code]
I have added comments to try and show what your code is doing
Chris
Edited by Chris Roper 2015-10-02
Greg Fordyce
Posted: 04:27am 01 Oct 2015
Quick question, your comments say 'read 1 bit' but the ONEWIRE READ reads bytes not bits, possibly some of the problem?
Try a simple program or even use the command prompt to try the commands and see what the response is from the devices. For example
PRINT a
and see what response you are getting. It may be that the devices aren't responding as you expect them to and this is causing some of your problems. One of the nice features of MMBASIC is being able to try things at the command prompt.
helltek
Posted: 05:12am 01 Oct 2015
The option 4 after pin number in ONEWIRE READ (or WRITE) reads only 1 bit. My routine reads the correct bits because I can read temperature and read pullup or pulldown of 2413 switch. I think, I have the DIMs now done correctly, following your examples, but I discovered problem with my search. When I hook up multiple devices, the search is reading them over and over until it hits maxdevices and stops with error. I need to figure out how to sort out which devices are already discovered and when there are no more devices to look for (last device). I will try to make sense of the appnotes. They are not exactly clear to understand.
Would be whole lot easier if there was 1-wire code for the Micromite to download and look up.
helltek
Posted: 04:57pm 01 Oct 2015
Update. My 1-wire search routine seems to work. It has to be tested with various 1-wire device combinations to see if it chokes on some similar serial numbers, but right now I have only few different devices to test.
Chris Roper
Posted: 08:35pm 01 Oct 2015
That's Great news helltek.
Well done.
It is a good feeling when your persistence pays off and you get it working.
After working through a few more problems like that one you will know MMBasic inside out
Chris
helltek
Posted: 08:55pm 01 Oct 2015
Thanks to you guys. I couldn't figure it myself. I still don't know how the program works. I have DIM with different names than the variables and no idea why it is that way, but it works and that's the end result I need.
Long time ago (in DOS days) I used Basic, Batch functions and Assembly. I never needed DIMs and I think the assembly language was the most logical, but when I look at Microchip assembly it doesn't look that simple, so I love the Micromite. It doesn't require any external parts, it is inexpensive and works great. Can't ask for more.
