Local Time 13:32 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Infrared
shellgray
Posted: 11:33am 25 Sep 2015
Hi Maximiters
I’m working with the original monochrome Maximite.
I’m having problems with Infrared communications, there is none.
I’m using the code from the MMBasic Language Manual and have read all the posts on this site,
but still can’t seem to get it running.
I have used an eBay bought infrared module
that has a led indicating the module is receiving and putting out a pulse stream.
I have verified the pulse stream buy using the count function on an input pin.
I have used other infrared receivers in the 40 KHz range
and have had the same results.
Any ideas?
Posted: 12:27pm 25 Sep 2015
Have you tried different remote transmitters. For the maximite it has to be Sony compatible. Even then, some of the more sophisticated ones will not work.
viscomjim
Posted: 04:43pm 25 Sep 2015
You might want to do a search for apple remote on this forum. Whitewizzard implemented this before but i cant recall what he did right now
Posted: 10:40pm 25 Sep 2015
  viscomjim said   You might want to do a search for apple remote on this forum. Whitewizzard implemented this before but i cant recall what he did right now
Here is the link to the thread implementing an Apple remote.
Note that with the new MM+, there is currently a bug with the built-in IR feature. Once this is fixed, the Apple Remote will work directly from Geoff's IR command.
Any questions then feel free to ask . . . .
WW
cosmic frog
Posted: 10:50pm 25 Sep 2015
A good 'tip' for testing ir remote controls is to use your phone camera to see if the irled is flashing, most cameras pickup ir.
Dave.
Posted: 11:03pm 25 Sep 2015
@shellgray
One thing to check is the IR receiver's voltage requirement.
Only yesterday I was using 4.2v (from a LiPo) to feed the +ve into the IR Rx and wondered why I was getting 'random' results. It was only when I used 5v from USB did it work correctly.
Just letting you know about this as it may be of some help in diagnosing your issue
shellgray
Posted: 03:21pm 08 Oct 2015
Going to dig up some more Remotes.
Thanks for your input guys :)
Posted: 01:14am 09 Oct 2015
  cosmic frog said   A good 'tip' for testing ir remote controls is to use your phone camera to see if the irled is flashing, most cameras pickup ir.
Dave.
A tester for remotes I use in any place I need a quick check, is any AM transistor radio. Press and hold a button with the remote facing the radio, and tune up and down the band till you hear the blurps from the remote. Even a $5 radio works well as an audible IR remote tester.
CircuitGizmos
Posted: 05:46am 09 Oct 2015
Search for "One for All One For All OARH01B 1 Device Universal Remote". That is one that is completely recognized (set to code 0001) and I've used quite a few times.
shellgray
Posted: 05:20am 28 Oct 2015
It turns out the five remote controllers I have are not sony compatible . I managed to score a sony remote and the project worked immediately. Thanks for all your input guys. Graham
Ledminer
Posted: 10:29am 26 Nov 2020
This is a very old topic but I shall try if anyone is still listening!  I DO need to decode Philips RC5 remote control with a micromite.  The Micromite is of course, only set up with Sony and NEC protocols.  Has anyone any code for RC5?
Thanks for looking
Posted: 11:38am 26 Nov 2020
I really wish people would stop resurrecting old topics.  It just forces others to wade through a lot of crap before they find the new entry.
Your question is new and it should have its own (new) topic
To address your question... sorry but I don't know of an RC5 implementation.  It would not be easy to do so you will be lucky to find one.
