Forum Index : Microcontroller and PC projects : Extend SPI range?
| Justplayin Guru Joined: 31/01/2014 Location: United StatesPosts: 330 |
I'm trying to figure out a way to connect a large string of the 8x8 LED matrix modules. Problem is the SPI connection fails after about 8 modules daisy chained together. Any suggestions what would might work as a signal booster/repeater/buffer/driver (pick your terminology)? I'm looking at connect about 28 modules to start with. Thanks, Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11908 |
Try one of these or just duplicate mosfet circuit but use the same voltage on each side |
Thanks for the suggestion! I bought some of those awhile back and never used them. I'll give it a try. All I have to do now is find them!
--Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2981 |
Hi Peter, Curtis, HaHa I just emailed Curtis this morning with exactly the same device.. What do they say about great minds?? Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Curtis, You would only need one of these I reckon as the Din is cascading through the Max7219 so should effectively be boosted/buffered EVERY module... The CS and CLK signals are paralleled so would need the buffer. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
I tried the one converter I had immediately on hand and had moderate success with 12 modules. Looked great when it was working! But, in the end my setup was still unstable. There are some issues I need to address such as I had everything plugged into a cheap breadboard, was using lots of crappy jumper wires and the converter had some really long leads already soldered om to it. I'm going to try again after I find my other converters and set the whole thing up a little more "in-line". If needed, I don't mind using a couple set of converters to boost the signals along, they're cheap. --Curtis I am not a Mad Scientist... It makes me happy inventing new ways to take over the world!! |
