Local Time 22:39 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Reverse.bas - a Time Sink
Chris Roper
Posted: 03:14am 22 Sep 2015
My archaeological dig through long forgotten sources revealed this little gem.
It is a simple game of skill originality written for the PDP11 in the early 70's and with only minor code tweaks it runs perfectly on the MicroMite.
Try it, but only if you have time to waist, it is so damn addictive:
[code]
80 Rem *** REVERSE WRITTEN BY BOB ALBRECHT, PEOPLE'S COMPUTER CO
90 Rem *** MODIFIED AND CONVERTED TO BASIC-PLUS BY DAVID AHL
95 Rem *** MODIFIED AND CONVERTED TO MMBASIC BY CHRIS ROPER
100 Print : Print "REVERSE -- A GAME OF SKILL" : Print
120 Randomize Timer
130 Dim A(20)
140 Rem *** N=NUMBER OF NUMBERS
150 N=9 : G=0 : T1=0
160 Input "DO YOU WANT THE RULES (YES OR NO)";AQ$
180 If LCase$(Left$(AQ$,1))="n" Then 210
190 GoSub 710
200 Rem *** MAKE A RANDOM LIST A(1) TO A(N)
210 A(1)=Int((N-1)*Rnd)+2
220 For K=2 To N
230 A(K)=Int(N*Rnd)+1
240 For J=1 To K-1
250 If A(K)=A(J) Then 230
260 Next J : Next K
280 Rem *** PRINT ORIGNIAL LIST AND START GAME
290 Print : Print "HERE WE GO ... THE LIST IS:"
310 T=0
320 GoSub 610
330 Input "HOW MANY SHALL I REVERSE";R
340 If R=1 Then Print "OOPS! ONE DOESN'T DO ANYTHING. AGAIN..." : GoTo 330
350 If R=0 Then 530
360 If R<=N Then 390
370 Print "OOPS! TOO MANY - I CAN REVERSE AT MOST"N : GoTo 330
390 T=T+1
400 Rem *** REVERSE R NUMBERS AND PRINT NEW LIST
410 For K=1 To Int(R/2)
420 Z=A(K)
430 A(K)=A(R-K+1)
440 A(R-K+1)=Z
450 Next K
460 GoSub 610
470 Rem *** CHECK FOR A WIN
480 For K=1 To N
490 If A(K)<>K Then 330
500 Next K
510 Print "YOU WON IT IN"T" MOVES !!!" : Print
520 G=G+1 : T1=T1+T
530 Input "TRY AGAIN (YES OR NO)";AQ$
550 If LCase$(Left$(AQ$,1))="y" Then 210
560 Print : Print "YOU PLAYED"G" GAMES AND REVERSED THE LISTS IN AN"
570 Print "AVERAGE OF"T1/G" MOVES PER GAME. HOPE YOU HAD FUN!" : GoTo 999
600 Rem *** SUBROUTINE TO PRINT LIST
610 Print : For K=1 To N : Print A(K); : Next K
650 Print : Print : Return
700 Rem *** SUBROUTINE TO PRINT THE RULES
710 Print : Print "THIS IS THE GAME OF 'REVERSE'. TO WIN, ALL YOU HAVE"
720 Print "TO DO IS ARRANGE A LIST OF NUMBERS (1 THROUGH"N")"
730 Print "IN NUMERICAL ORDER FROM LEFT TO RIGHT. TO MOVE, YOU"
740 Print "TELL ME HOW MANY NUMBERS (COUNTING FROM THE LEFT) TO"
750 Print "REVERSE. FOR EXAMPLE, IF THE CURRENT LIST IS:"
760 Print : Print "2 3 4 5 1 6 7 8 9"
770 Print : Print "AND YOU REVERSE 4, THE RESULT WILL BE:"
780 Print : Print "5 4 3 2 1 6 7 8 9"
790 Print : Print "NOW, IF YOU REVERSE 5, YOU WIN!"
800 Print : Print "1 2 3 4 5 6 7 8 9" : Print
810 Print "NO DOUBT YOU WILL LIKE THIS GAME OF SKILL, BUT"
820 Print "IF YOU WANT TO QUIT, REVERSE 0 (ZERO)." : Print : Return
999 End
[/code]
Chris
http://caroper.blogspot.com/
vegipete
Posted: 08:17am 22 Sep 2015
YOU PLAYED 6 GAMES AND REVERSED THE LISTS IN AN
AVERAGE OF 11.5 MOVES PER GAME. HOPE YOU HAD FUN!
Now I must force myself to stop.
What a brute force way to generate the numbers 1-9 in random order!
I changed that part of the code to this:
210 Rem *** MAKE A RANDOM LIST A(1) TO A(N)
220 for K = 1 to N : A(K) = K : Next K
230 for K = 1 to N
240 J = Int(N*Rnd(0))+1 'Change "Rnd(0)" to "Rnd" for MMBasic
250 tmp = A(K) : A(K) = A(J) : A(J) = tmp
260 Next K
twofingers
Posted: 01:48pm 22 Sep 2015
@Chris
I do not want to stop your commitment, but this and many other old and new Basic programs are already available in Hugh's MMBasic Library. Just in case ...
Michael
Chris Roper
Posted: 07:37pm 22 Sep 2015
Thanks Michael,
I must admit I looked at the library when I first joined but subsequently forgot about it Thanks for the reminder.
I wasn't really looking for games but in my research stumbled on these and had a bit of fun with them and thought others may like the diversion too. Next Time I will look in the Library before posting, but at least these have raised awareness of it
Chris
