Local Time 15:50 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Back to the ’70’s - Lava Lamp
Posted: 09:17pm 03 Sep 2015
I saw this program on the PureBasic forum and thought it could be translated to MMBasic.
It is very slow but not too bad considering the amount of processing for each pixel.
' TassyJim
' 4th September 2015
' from a program in PureBasic by 'Idle' on the PureBasic forum.
OPTION EXPLICIT
DIM NumCircles = 5, Width = 240, Height = 200, pix = 2
DIM re
DIM mc(NumCircles,6)
main:
CLS
DO
re = initialise(NumCircles)
re = draw(NumCircles,pix)
LOOP
END
FUNCTION initialise(NumCircles)
LOCAL i
FOR i = 0 TO NumCircles
mc(i,1) = RRandom(0, Width) 'x
mc(i,2) = RRandom(0, Height) 'y
mc(i,3) = RRandom(20, 80) 'd
mc(i,4) = mc(i,3)/ 2 'r
mc(i,5) = RRandom(-3, 3) 'vx
mc(i,6) = RRandom(-3, 3) 'vy
NEXT i
END FUNCTION
FUNCTION draw(NumCircles,sx)
LOCAL x, y, dx, dy, sum, dd, i
FOR i = 0 TO NumCircles 'move circles AND keep in bounds
mc(i,1) = mc(i,1) + mc(i,5)
mc(i,2) = mc(i,2) + mc(i,6)
IF mc(i,1) - mc(i,4) <= 0 THEN
mc(i,5) = ABS(mc(i,5))
ENDIF
IF mc(i,1) + mc(i,4) >= Width THEN
mc(i,5) = -ABS(mc(i,5))
ENDIF
IF mc(i,2)- mc(i,4) <= 0 THEN
mc(i,6) = ABS(mc(i,6))
ENDIF
IF mc(i,2) + mc(i,4) >= Height THEN
mc(i,6) = -ABS(mc(i,6))
ENDIF
NEXT i
x = 0
WHILE x < Width 'plot routine
'print x
y=0
WHILE y < Height
sum = 0
dx = x - mc(i,1)
dy = y - mc(i,2)
dd = dx * dx + dy * dy
sum = sum + (mc(i,3) * mc(i,3) / dd)
NEXT
IF sum > 3 THEN
PIXEL x,y,RGB(0, 255, 0)
ELSE
PIXEL x,y,RGB(0, 0, 0)
ENDIF
y = y + sx
WEND
x = x + sx
WEND
END FUNCTION
FUNCTION RRandom(min,max)
RRandom = RND()*(max-min) + min
END FUNCTION
You can change the default settings.
pix is the 'resolution' 2 sets every second pixel. 1 is nicer to look at but 4 times as long to paint a screen.
I have tested it on MX170 with 2.4 inch display and MX470 with 7 inch.
Start with the default settings - if you try a full screen 7inch be prepared for a long wait.
Posted: 09:30pm 03 Sep 2015
Cute.
paceman
Posted: 02:10am 04 Sep 2015
Slow alright - thank heavens for CFunctions!
Posted: 04:09pm 04 Sep 2015
I remember these kinds of line-by-line graphics drawings from my days with the Atari.
This was EXACTLY how it used to draw the images too.
