Local Time 15:50 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Firmware 4.7 and LOAD command..
sagt3k
Posted: 11:10pm 02 Sep 2015
Hi Geoff
I have a doubt on LOAD command on new firmware 4.7.
I have a program in RUN... then I call LOAD a file and I can run the new program ..correct?
But If I do pieces of code and save code as library in SD, can I recall/load from my SD and integrate or merge this code? So re-RUN my original code but with the new merged.
Posted: 12:41am 03 Sep 2015
Not that I am aware of.
LOAD command will erase the current program in memory, in favour of the new file you are loading. Not sure that merging in memory would be easy to do either. Even the Maximite series of computers cleared the program memory if you were LOADing or CHAINing programs.
An interesting idea - I will be watching this thread.
sagt3k
Posted: 01:10am 03 Sep 2015
Hi Grogster...
Thanks ...Good idea ..
For example in OPTION Geoff can include LIBRARY.
So I can load my.BAS and load and append the current CODE with the library.BAS that found in uSD. For example I can save in uSD pieces of code saved by RUN program ...I will be able to save status code and reload after a power off/on.
Posted: 01:43am 03 Sep 2015
A Maximite will do just that. A MicroMite does not i believe.
Posted: 02:25am 03 Sep 2015
Yes, at this time you cannot merge a file from the SD card.
I expect that there will be more an more requests for this sort of functionality as people start using the MM+ as a computer rather than a controller. At some point I may have to come up with two versions of the firmware (one optimised for use as a computer and the other as a controller).
