Local Time 15:50 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Explore 64 worksheets
Greg Fordyce
Posted: 09:10am 30 Aug 2015
I have created some worksheets to use when planning/laying out a project using the Explore 64 module. It is basically a list of the pin numbers along with a key that describes their capabilities and a place to write down what is connecting to it and any other notes you might add. Hopefully it will be useful when planning what connects where in a new project.
At the moment there are 2 worksheets, a blank one and one for using with a ssd1963 display as shown in the examples in the uM+ advanced features manual. They should print out on a single sheet of a4, letter might need some tweaking to get on a single sheet. They have been created using Google docs and I am sharing them from my Google drive folder. Use, copy and share if you find them useful.
MM templates
Enjoy,
GregEdited by Greg Fordyce 2015-08-31
MMAndy
Posted: 01:04pm 30 Aug 2015
Pin 14 is on-board SD card detect?
try this ....
setpin 14, off
Error: Pin 14 is reserved on startup <---- for SD card? Edited by MMAndy 2015-08-31
Greg Fordyce
Posted: 01:07am 31 Aug 2015
Thanks MMAndy. I followed the example in the Advanced Features manual, but your right about pin 14. I have updated the sheets to use pin 18 for touch select and have posted a suggested change in the beta thread.
Greg
MMAndy
Posted: 02:35am 31 Aug 2015
Also, Pin 22?
http://geoffg.net/Downloads/Micromite/MMPlusIssues.txt
Issues: - Pin 22 on the 64-pin Micromite Plus will be unavailable whenever MMBasic is configured for the SSD1963.
"if not present display will use 3.3v for backlight"
This statement might confuse a new bee.
You cannot drive the backlight with the USB +5V but with an external 5V supply.
Also, if you try to use the on-board 3.3 V regulator out with the max. of 250 ma. you
could also have problems?
Edit ...
Power Consumption MM+ / keyboard, TFT 7" display:
MicroMite+ running: 77 ma. - 80 ma. @ 100 Mhz
Keyboard: 100 ma. @ 5V
7" Display Electronics: 100 ma. @ 3.3V
7" Display Backlight: 330-620 ma. @5V 10% brightness 133 ma. and 100% 433 ma.
Edited by MMAndy 2015-09-01
Greg Fordyce
Posted: 03:57am 31 Aug 2015
I've added a note for pin 22 and updated the 5V note.
