Local Time 22:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TONE command on MicroMite ?
f1fco
Posted: 04:37am 29 Aug 2015
hello,
TONE command exist on Maximite software
output is a "pure" sinus
I make DTMF tones : 2 simultaneous frequencies (not exactly the same level : I mix the right and left level in a 10Koms potentiometer)
combination of frequencies 697, 770, 852, 941 and 1209, 1336, 1447, 1633 Hz
is it possible to have the same function on the Micromite ?
the PWM command is a square wave
a CFunction perhaps ?
or make a "strong" filter for the square wave ? what components ?
thank you for help
Pierre
73s de F1FCO
f1fco
Posted: 04:38am 29 Aug 2015
what is the "precision" in frequency with PWM command ?
with TONE command, 1 Hz is possible (on the DTMF frequencies)
73s de F1FCO
Posted: 05:05am 29 Aug 2015
Yes, the TONE command is not in the Micromite and I doubt that a CFunction could be used to replicate the function.
It may be something that could be added to the firmware but it will take some research. At the least it would share the same output pins as PWM 1A and 1B.
Does anyone else have a need for this function? Is it an urgent need?
Posted: 05:39am 29 Aug 2015
TONE (or BEEP) with as many of the following parameters: Freq, Duration, Volume; this would be a 'nice to have' for my requirements
cosmic frog
Posted: 06:53am 29 Aug 2015
Yes Tone with volume would be great!
Posted: 06:58am 29 Aug 2015
Slight modification based upon what used to be common on 80's home computers:
TONE channel,freq,duration,volume
I know the MM+ is NOT a home computer - just suggesting this for consideration if ever Geoff does implement a TONE type command.
In the above, Channel represents Left, Right or Both (i.e. stereo).
With this command it was possible to create some great music for integrating into programs (not quite polyphonic, but certainly better than just a standard 'beep'.
WW
Justplayin
Posted: 08:30am 29 Aug 2015
Yes! Being able to output even some simple sounds would be great. I have been thinking about building a MicroMite powered "pill-minder" to remind my mother to take her various medications on time.
--Curtis
hitsware
Posted: 09:58am 29 Aug 2015
PWM is very usefull for audio output.
(As implied by initial post)
Edited by hitsware 2015-08-30
hitsware
Posted: 10:04am 29 Aug 2015
  WhiteWizzard said   Slight modification based upon what used to be common on 80's home computers:
WW
That 'TONE' was usually a squarewave...
hitsware
Posted: 10:06am 29 Aug 2015
  Geoffg said   Yes, the TONE command is not in the Micromite and I doubt that a CFunction could be used to replicate the function.
No urgency at all, but it's nice the way TONE will sweep so smoothly .
Chris Roper
Posted: 10:34am 29 Aug 2015
Here is a Program I wrote a couple of years ago on the Original MicroMite on the MX150 Chip, it should work on the MM Mk2 as well.
It scans a 1 Octave Keyboard and outputs 2 Tones on the 2 PWM Channels.
I was emulating an electric Organ so the code is set up specifically to generate harmonic effects by mixing the two outputs.
It made some very pleasant music, or should I say it could if I was actually musically inclined. With a Suitable Amp, I used powerd PC speakers, it makes a passable church organ effect.
[code]
Keypad KeyCode, KP_Int, 21, 22, 23, 3, 18, 25, 2, 7 ' 1 Octave keyboard
setpin 6, AIN ' Gate Duration
setpin 9, DOUT ' Mode LED1
setpin 10, DOUT ' Mode LED2
setpin 14, DOUT ' Mode LED3
setpin 15, DOUT ' LFO
PIN(15) = 1
LFO_F = 0 ' LFO1 Off
LFO_D = 50 ' LFO1 Default Pulse Width
Duty = 50 ' Osc2 Default Pulse Width
Chorus = 1 ' Chorus Effect Off (Osc2 tracks Osc1)
Octave = 4 ' Keyboard range 261.63Hz - 523.25Hz (Middle C)
SETTICK 200, LFO_Int, 3 ' Low Frequancy Oscillator
' Map keyboard to musical notes
IF KeyCode = 3 then MyNote = 1 ' C
IF KeyCode = 2 then MyNote = 2 ' C#
IF KeyCode = 1 then MyNote = 3 ' D
IF KeyCode = 20 then MyNote = 4 ' D#
IF KeyCode = 9 then MyNote = 5 ' E
IF KeyCode = 6 then MyNote = 6 ' F
IF KeyCode = 5 then MyNote = 7 ' F#
IF KeyCode = 4 then MyNote = 8 ' G
IF KeyCode = 21 then MyNote = 9 ' G#
IF KeyCode = 22 then MyNote = 10 ' A
IF KeyCode = 8 then MyNote = 11 ' A#
IF KeyCode = 7 then MyNote = 12 ' B
IF KeyCode = 11 then MyNote = 13 ' C
if MyNote > 0 then ' Note Key Played
if Trigger then
'Start the Gate
Gate = 250 * PIN(6) + 10
' Turn off Trigger
Trigger = 0
' Send Debug info once per Note
? "note1" Freq1 " Chorus" Chorus " Chord" Chord " Octave" Octave " Duty" Duty " Gate" Gate
endif
if Gate > 0 then ' Note is currently Playing
freq2 = 30.87 * ((2^(1/12)) ^ (MyNote + Chord * 12)) * 2^(Octave - 1)
freq1 = 30.87 * ((2^(1/12)) ^ MyNote) * 2^(Octave - 1)
if freq2 > 20 then pwm 2, freq2 * Chorus, Duty
if freq1 > 20 then pwm 1, freq1, 50
Gate = Gate - 1
Else ' Gate is Closed, Stop the Note
pwm 1, STOP
PWM 2, STOP
MyNote = 0
endif
endif
Loop
LFO_Int:
PULSE 15, 100
IRETURN
KP_Int: ' a key press has been detected
Trigger = 1
IF KeyCode = 23 then
if shift = 1 then
Chorus = Chorus - 0.0025
elseif shift = 2 then
Duty = Duty - 5
elseif shift = 3 then
Chord = Chord - 1
else
Octave = Octave - 1
if Octave < 0 then Octave = 0
endif
Trigger = 0
endif
IF KeyCode = 10 then
if shift = 1 then
Chorus = Chorus + 0.0025
Duty = Duty + 5
Chord = Chord + 1
else
Octave = Octave + 1
if Octave > 7 then Octave = 7
endif
Trigger = 0
endif
IF KeyCode = 0 then
shift = shift + 1
if shift > 7 then shift = 0
port(9,2,14,1) = shift
Trigger = 0
endif
IRETURN
[/code]
You may be able to use my Tone Functions from that.
Chris
http://caroper.blogspot.com/
f1fco
Posted: 11:22am 29 Aug 2015
thank you to all for answers
I have the real answer but I hope...
if Geoff can add the TONE command, I can wait... a (long) time
to make a "syntesizer", the code of Chris Roper is very useful
square wave is an advantage for harmonics effects
finally, can you help me for values of a filter ?
R and C to quasi transform sqare in sinus (a low pass filter)
Pierre
73s de F1FCO
hitsware
Posted: 12:25pm 29 Aug 2015
Here Ya Go ....
skyv
Posted: 10:51pm 29 Aug 2015
Hi hitsware
The link doesn't appear to be working for me.
Could you please check.
skyv
Chris Roper
Posted: 10:53pm 29 Aug 2015
  skyv said   Hi hitsware
skyv
Works fine for me
Chris
p.s.
Talking of links here is a good description of generating pure Sine Waves with a PIC Micro. It will give you a good idea of what is involved and how to filter it.
You may even end up with a useful tool :)
http://www.romanblack.com/onesec/Sine1kHz.htmEdited by Chris Roper 2015-08-31
skyv
Posted: 10:57pm 29 Aug 2015
Thanks Chris
I'll check my computer settings
skyv
hitsware
Posted: 03:20am 30 Aug 2015
http://www.learningaboutelectronics.com/Articles/Low-pass-filter-calculator.php
f1fco
Posted: 03:48am 30 Aug 2015
thank you for links
I have forget my electronics laws...
I will try with 1OOO or 820 ohms and 100nF and see the result on my scope
Pierre
73s de F1FCO
jimbotron
Posted: 04:54am 30 Aug 2015
Hi Pierre,
Try using different filters for the different pins. One of the pins will be generating signals under 1KHz and the other will be higher. Use a lower cutoff frequency for the low frequency pin to get better sine waves.
f1fco
Posted: 10:33am 30 Aug 2015
hi Jimbotron,
judicious suggestion, you are right, I try it
thank you,
PierreEdited by f1fco 2015-08-31
73s de F1FCO
