Local Time 10:01 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 4x 10/12/13 bit A/D converter module
Posted: 11:05pm 28 Aug 2015
Hi All,
I have designed a little board for capturing 4 analog values.
It can be used with the 3001/3201/3301 A/D converters from Microchip.
Also has a voltage regulator for a precision VREF.
That can be the MCP1541 for 4.096v or a MCP1525 for 2.5v.
I tried to place the parts as good as possible to minimize noise.
Some feedback about the ground planes would be welcome as that is my weak point with analog/digital mixed circuits.
The reason for 4 chips and not a single 4 channel chip is that all 4 analog converters can be sampled at exactly the same time.
Schematic:
PCB is 23x18mm.
Top layer:
Bottom layer:
3D:
Bonus points for someone who figures out the name of this module.
This can also easily be combined with another module i have (USB->Serial with a PIC16F1455) to create an 4 channel A/D with serial output (USB/I2C or Serial). On my todo list. Whit that you can then just add an openlog device and have an instant 4 channel analog 'recorder'.
Edited by TZAdvantage 2015-08-30
Posted: 05:59am 01 Dec 2015
I have tweaked the design a bit. Made the groundplanes better, added a separate VREF connection.
This is the 3rd Microblock that is ready to be manufactured.
I still have a few more to go. :)
Edited by MicroBlocks 2015-12-02
panky
Posted: 05:07pm 06 Dec 2015
Great job Microblocks - can you provide any specs, particularly for 12 bit mode ie, base resolution and accuracy?
Doug.
Posted: 03:47am 07 Dec 2015
Hi Panky, I think i can best point you to the datasheet as that contains all the details.
http://ww1.microchip.com/downloads/en/DeviceDoc/21290F.pdf
This is specifically made to sample 4 analog inputs at the same time.
It is almost like a 4 bit wide 'SPI'.
If you need 13 bit then this chip is used:
http://ww1.microchip.com/downloads/en/DeviceDoc/21700E.pdf
Edited by MicroBlocks 2015-12-08
