jman Guru Joined: 12/06/2011 Location: New ZealandPosts: 711
Posted: 09:25pm 22 Aug 2015
Hi All
Using a MM+ with a colour LCD I would like to use the Text command
without it using a background colour.
I have a BMP for the background and would like to overlay the text on the bmp
without the text setting its own background colour
Is this possible ?
Jman
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11908
Posted: 01:27am 23 Aug 2015
Not without some significant changes to the firmware. The way it works is that a display region is created the size of the character, the software then clocks through the character's bitmap and either sends the foreground or background colour without having to do any further pixel positioning
To do what you want the firmware would need to send each foreground pixel individually and re-position over each background pixel. This would be much slower.
It could be done in a CFunction but it would be a pretty complex one and not fast
