Local Time 15:36 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM Edit Version 3.6.2
Posted: 07:05pm 20 Aug 2015
A few small changes
When doing 'remove blank lines and comments', any white space is also removed on lines which had comments.
When you go to Connect/New...
There is an option add a list of com ports you want excluded from searches. The list needs a space between ports. eg "COM1 COM3". Remember to "save" before exiting.
This is handy if you have a modem or other device you want left alone.
Currently, you can still select the excluded port manually.
Fixed a bug when you opened file manager with a serial port that doesn't have a 'mite attached.
TFTcolour.exe is included in the distribution and there is a link to it in the File menu as well as a desktop shortcut.
I have attempted to make TFTcolour's 'picker' work on displays set to other than 100%. F1 will give you the options.
Download the full update from the usual location http://www.c-com.com.au/MMedit.htm
The attached ZIP contains the replacement TKN file and an updated TFTcolour.exe.
Put TFTcolour.exe into MMEdit's program folder if you want the File menu link to work.
2015-08-21_050431_MMedit.zip
Posted: 07:46pm 20 Aug 2015
Thanks once again Jim
