Local Time 22:21 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ End Sub
palcal
Posted: 08:20pm 18 Aug 2015
I have some code that works perfectly well with the 170 chip, but when I loaded it into the MM+ I have a problem. This is part of the code:-
SetTick 200, POSITION, 1
sub POSITION
If Touch(x) >215 And Touch(x) < 255 Then
Latitude$ = Left$(arg$(3) ,2)+" "+Mid$(arg$(3) ,3)+" "+arg$(4)
Longitude$ = Left$(arg$(5) ,3)+" "+Mid$(arg$(5) ,4)+" "+arg$(6)
CLS(Yellow)
Text 150,100,"CURRENT POSITION",CM,2,2,RGB(Cyan)
Text 145, 140, "Lat " + Latitude$,CM,2,2,RGB(Cyan)
Text 145, 180, "Lon " + Longitude$,CM,2,2,RGB(Cyan)
Flags= 0
Pause 10000
GoSub Display
ELSE END SUB
endif
GoTo START
When working, if the screen is touched it branches to this SUB and displays the current position for 10 secs. before returning to the SUB DISPLAY which displays the normal screen.
The problem is the settick goes to the Sub POSITION, the screen is not touched so TOUCH(X) and TOUCH(y) are both -1 (checked this)
but the ELSE END SUB is not processed and the program goes to START.
This code has been working perfectly with the 170 chip for many months.
Paul.
BobD
Posted: 08:51pm 18 Aug 2015
Paul
2 things and I can't test either. Instead of END SUB it should probably be EXIT SUB and it may need to be on the line following the ELSE.
The rules may be tighter with different firmware.
Posted: 09:03pm 18 Aug 2015
Paul,
BobD is correct in that the ELSE has to be on its own line with the 'else statement' also on its own line.
See Page 52 of Manual (v4.7) which shows syntax for single line and multi-line IF statements.
WW
palcal
Posted: 09:29pm 18 Aug 2015
I'm running 4.7 on the 170s but it may be different in this version. Will try later.
Thanks for the replies, will get back.
Paul.
Edit.
Just altered the code and it works fine. Thanks again.
Paul.Edited by palcal 2015-08-20
Posted: 09:41pm 18 Aug 2015
Paul,
With subroutines you need to make sure that it has a start and an end.
Otherwise the interpreter will loose track of where it is.
A subroutine starts with the word SUB followed by the name.
[code]
SUB mySubroutine
[/code]
after this line you can write the code that has to be executed when the subroutine is called.
after the code you need to 'close' the subroutine with
[code]
END SUB
[/code]
This will cause the interpreter to go back to were it was when the subroutine was called.
You can not jump out of a subroutine with a GOTO. The interpreter will then not see an END SUB and will think that it is still inside the subroutine. This should trigger an error but interpreters are normally not so strict. Eventually the program wil run out of memory because each time it executes a subroutine it has to remember were to go back to.
If you need to get out of a subroutine use EXIT SUB.
Also it is best to not use any pause in subroutines that are used with timers or interrupts.
You can also consider using then new GUI commands to capture a touch.
[code]
Micromite Plus only.
In addition, on the Micromite Plus an interrupt
can be triggered on touch down and up.
The following command will set up the interrupt:
GUI INTERRUPT down [, up]
Where 'down' is the subroutine to call when a touch down
has been detected. And optionally 'up' is the subroutine
to call when the touch has been lifted from the screen
('up' and 'down' can point to the same subroutine if required).
Specifying the number zero (single digit) as the argument
will cancel both of these interrupts. ie:
GUI INTERRUPT 0
[/code]
Edited by TZAdvantage 2015-08-20
palcal
Posted: 09:55pm 18 Aug 2015
Thanks, I changed the code when I switched from push buttons to touch. With the push buttons I used the interrupt to set a flag and then return to the main code so it didn't spend long in the interrupt. I forgot about using PAUSE in an interrupt not being good practice. I will try the GUI INTERRUPT command or maybe go back to using the SUB to just set a flag.
Paul.
Posted: 10:08pm 18 Aug 2015
With TOUCH, is is a good idea to store the X Y values quickly then do you tests. The touch(X) will be constantly changing and that can make life interesting when you are trying to do tests.
SUB tapped
LOCAL tx,ty
tx=TOUCH(X)
ty=TOUCH(Y)
IF ty < 120 AND ty >0 THEN
etc...
Be prepared for some -1 values as the finger leaves the screen.
JimEdited by TassyJim 2015-08-20
palcal
Posted: 11:08pm 18 Aug 2015
When using the GUI INTERRUPT command, can I have more than one interrupt.
I tried it and only one interrupt works. Reading the manual I don't think I can.
Posted: 08:37am 19 Aug 2015
  palcal said   When using the GUI INTERRUPT command, can I have more than one interrupt.
You can have two interrupts. One for touch down and another for touch up.
Within the interrupt use a SELECT CASE statement or some other way to determine what is being touched. See page 23 of the advanced manual.
palcal
Posted: 11:48am 19 Aug 2015
Thanks Geoff, was reading all that last night. I just have to get my little brain to understand it all, but I'm confident I will have it up and running soon.
Paul
palcal
Posted: 02:51pm 19 Aug 2015
Trying to test my new code but MM+ wont connect to my GPS receiver. I am using the command 'OPEN "COM2:4800" As #1' but I see in the advanced Manual that the OPEN command is used to OPEN a file for reading or writing. Is there any conflict here.
Paul.
Posted: 03:10pm 19 Aug 2015
It should work for either COM ports or files and your command looks OK to me.
Posted: 03:17pm 19 Aug 2015
I have done a bit of playing around with serial on the new MM+, and can confirm that the serial ports do work, so this command should be working for you.
What is the rest of the code you are using to talk to the GPS on COM2?
It is quite possible that there is an error there, as COM2 to the GPS device should actually be open.
At the command prompt, and assuming that some data should have been sent by the GPS module, type the following:
? LOC(#1)
If the number is zero, no data has been received. If the number is not zero, then there is data from the GPS sitting in COM2's receive buffer waiting for you. Edited by Grogster 2015-08-21
palcal
Posted: 03:25pm 19 Aug 2015
The rest of the code is OK I have it working on other devices. Just wanted to confirm the OPEN command before I looked elsewhere.
Paul.
palcal
Posted: 06:55pm 19 Aug 2015
OK Iv'e been working on this for most of the day. I just can't get the COMM port to work on the Explore-64 board. I checked the TX connection from the GPS back to pin 59 on the 470 (I'm using COMM1) and it is OK. I have printed out what I am receiving and the characters are rubbish. If I connect the GPS to the board running a 170 chip with exactly the same code it works fine.
I'm stumped and need a break maybe alcohol is the answer.
Paul.
Posted: 08:13pm 19 Aug 2015
Rubbish characters are usually a wrong baud rate or inverted signal.
Try adding 'INV' to the end of your comspecs. You will need a few of the optional parameters in there as well.
palcal
Posted: 08:22pm 19 Aug 2015
  Quote  Try adding 'INV' to the end of your comspecs
I doubt that could be the problem as it all works on the 170 chip.
Is there a way to test the COMM PORT by tying TX and RX together.
Paul.
palcal
Posted: 07:23pm 22 Aug 2015
OK after many hours I have this working in a sort of fashion, but still have a problem with 'TOUCH'
When a button is touched I want to go to another screen so I had to use GUI DELETE to get rid of the buttons but when I return to the main screen and redraw the GUI BUTTONS they don't work.
Try this short example
GUI INTERRUPT CHOOSE
START:
Screen
Loop
Sub Screen
GUI BUTTON #1, "SELECT",50,100,185,40,RGB(Black),RGB(Green)
End Sub
CHOOSE:
GUI Delete #1
CLS
Pause 2000
GoTo Start
After the interrupt the screen is redrawn but the button won't work.
Paul.
Edit: I tried GUI HIDE and GUI RESTORE with the same result.Edited by palcal 2015-08-24
Posted: 07:53pm 22 Aug 2015
Can not test it here but rewrite your code like this:
[code]
ActiveScreen = 0
NextScreen = 1
if NextScreen <> ActiveScreen then
Screen NextScreen
endif
Loop
Sub Screen(value)
if value = 1 then
endif
if value = 2 then
GUI DELETE #1
CLS
pause 2000
NextScreen = 1
endif
ActiveScreen = value
End Sub
Sub CHOOSE
'You can add code here to examine the touch location and decide which screen
'you want to show.
NextScreen = 2
End Sub
[/code]
Edited by TZAdvantage 2015-08-24
palcal
Posted: 08:45pm 22 Aug 2015
Thanks TZ but your code won't work for me. When you a next near an MM+ can you test and advise.
Paul.Edited by palcal 2015-08-24
