Local Time 15:36 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : elseif statement
Chrisk
Posted: 11:46pm 16 Aug 2015
Hi Guys
I have 2 temperature sensors and I wish to carry out different subroutines based on their values.
The following example gives Error: No closing bracket in expression.
Obviously the syntax is not correct for MMBasic 4.5
I also have a need to go to a sub if T1 or T2 are over certain values.
I have managed the later but it is very slopy.
TRON
T1 = 25
T2 = 30
If T1 > T2 then
gosub greater
elseif ( T1 > 18 && T1 < 28 ) then
gosub abcd
else
endif
end
greater: 'test1 OK
end
abcd: 'test2 OK
end
Any suggestions would be greatly appreciated.
Chrisk
Chris Roper
Posted: 11:57pm 16 Aug 2015
The following is untested as I don't have a uM to hand, but it is how I would do it.
[code]
TRON
T1 = 25
T2 = 30
If T1 > T2 then greater
if ( T1 > 18 && T1 < 28 ) then abcd
end
sub greater
'test1 OK
end sub
sub abcd
'test2 OK
end sub
[/code]
Chris
EDIT:
Just realised in the above that is both conditions are true it will run both subs.
If that is not acceptable then try:
[code]
TRON
T1 = 25
T2 = 30
If T1 > T2 then
greater
else
abcd
end if
end if
end
sub greater
'test1 OK
end sub
sub abcd
'test2 OK
end sub
[/code]
Edited by Chris Roper 2015-08-18
http://caroper.blogspot.com/
twofingers
Posted: 12:15am 17 Aug 2015
@Chrisk
what do the "&&" mean? Is that MMBasic?
Michael
Edit:
as Chris Roper mentioned:
[code]T1 = 25
T2 = 30
If T1 > T2 then
greater
end
else if ( T1 > 18 and T1 < 28 ) then
abcd
end
else
Print "oops"
end if
end
sub greater
Print "test1 OK
end sub
sub abcd
Print "test2 OK "
end sub [/code]
Note: Using "GOSUB" is old style and for compatibility only (IMHO).
Edited by twofingers 2015-08-18
The lone and ...
Chris Roper
Posted: 12:20am 17 Aug 2015
&& is a Logical Operator, it will evaluate the first condition:
T1 > 18
then the second Condition:
T1 < 28
then if Both Conditions are TRUE it will return TRUE as the result, otherwise it returns FALSE and the subroutine call will be ignored.
the longhand way of doing it would be:
[code]
if T1 > 18 then
if T1 < 28 then
'do something
end if
end if
[/code]
Hope that helps
Chris
[EDIT]
Replace && with the word AND
I am currently chopping and changing between 3 dialects of BASIC and 2 of C so keep forgetting which one uses which syntax
I am not so sure that MM Basic has a && operator but it does have AND
They are the basically same thing, just syntax difference between languages.
(there are differences but they are subtle and irrelevant in this case, so I won't try to confuse you with an explanation)
EDIT 2: @twofingers, just realised you were asking ChrisK, I read it as Chris but I may as well let the post stand.
twofingers
Posted: 12:36am 17 Aug 2015
Please read the edit!
edit:
  Quote  EDIT 2: @twofingers, just realised you were asking ChrisK, I read it as Chris but I may as well let the post stand.
Edit2:
for MMBasic <=4.5 the "Else If" must be written as "ElseIf"!
The lone and ...
Chrisk
Posted: 03:18pm 17 Aug 2015
Thanks Guys for the prompt replies.
Just to confirm (tested)that MMBasic does not accept the && operator but the AND in its place does work.
ChrisK
