Local Time 15:23 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 3 Screen Test...
Zonker
Posted: 12:40pm 10 Aug 2015
Good afternoon all...
I think I have some interesting "head scratching" stuff going on...
Currently playing with the new CGmicroboard2 and have a 2.4" Display strapped on.
I want to use this hardware to run the "data gathering" part of the EIS system, so it needs a basic "tab" based screen interface for the end user...
When it runs, it has to create all the GUI Objects for all 3 screens. As each screen group is created, I "hide" the controls, so the next screen can have a blank screen to start with. When the "INIT" part is done, I force the screen to the "Status Screen" state before hitting the main DO loop...
Just for fun, I set a tick INT to change the value of two LED objects on the stat screen.
SO...
When you change to the "Data" screen, the two LED's seem to produce the "object value zero" drawing behavior when the tick INT fires, even when the object is currently in it's "hidden" mode...
Also, I am having trouble with radio buttons not "grouping up" correctly in frames...
Now, maybe this could just be a "newbie" thing, but I have been playing around with it for a few hours now, and looks OK to me....
2015-08-10_223501_3_Screen_Test.zip
Anyway, have a peek at it and see what you think... Rob's CG2 PCB seems to be working perfectly, so something ain't right... Probably me....
Thanks Gent's
