Local Time 22:01 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RUN a file?
kiiid
Posted: 10:47pm 02 Aug 2015
Is there any chance to have this functionality soon?
I started writing something BIG and the code becomes too long so it has to be split in a few files on SD. But without this command, I see no chance for that happening. Is there any possible workaround at the moment, probably by using LOAD instead?
Thanks!
http://rittle.org
Posted: 10:59pm 02 Aug 2015
Try LOAD filename.bas,R.
From the advanced manual:
LOAD $fname [, R]
Load a BASIC program from the SD Card. The optional suffix ",R" will cause the program to be run after it has been loaded.
kiiid
Posted: 11:00pm 02 Aug 2015
Huh? I have missed that :)
Thanks!
http://rittle.org
Posted: 11:02pm 02 Aug 2015
...that's for the new MM+ - I assume that is what you are using?
kiiid
Posted: 12:00am 03 Aug 2015
I got interested in the practical use of MM only after the SD support appeared officially, so MM+, yes.
http://rittle.org
Chris Roper
Posted: 12:46am 03 Aug 2015
Is SD supported on the MX170 version of MM+ ?
That would be very useful if it is.
http://caroper.blogspot.com/
Posted: 01:32am 03 Aug 2015
As I understand it, there is not enough flash by a long way, to include the filesystem on the 170 and still keep all the existing functionality - hence the 470 MM+ unit.
Chris Roper
Posted: 02:44am 03 Aug 2015
  Grogster said   As I understand it, there is not enough flash by a long way, to include the filesystem on the 170 and still keep all the existing functionality - hence the 470 MM+ unit.
I had a feeling that would be the case :)
It is amazing how much Geoff has managed to squeeze in as it is....
kiiid
Posted: 03:05am 03 Aug 2015
Until we see the '190 chips... :)
http://rittle.org
