Local Time 21:51 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : console pins
viscomjim
Posted: 05:43am 22 Jul 2015
Can a mmbasic program re-purpose the console RX and TX pins as I/0 pins. For instance, can I send my program using mmedit to the uMite with option autorun on, disconnect the console cables and attach whatever my i/o hardware is to those pins, repower the uMite and have it use those pins? Or even just send mmbasic with my program to the uMite using PicKit3 and hex file?
Thanks!Edited by viscomjim 2015-07-23
Posted: 10:20am 22 Jul 2015
You can do this only on the Micromite Plus and only after you have used OPTION CONSOLE OFF.
