Local Time 15:22 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : maximite stop working video
crosstydown
Posted: 10:40am 14 Jul 2015
hi all,
my circuit gizmo work for about 1 year to control my greenhouse but today the video stop working but program still working and is not my monitor try on another monitor but no video !!! if someone know what to do
Posted: 11:18am 14 Jul 2015
Could there be a broken track on the PCB at the VGA output? If possible, perform a continuity check between each vga socket pin and the relevant point on the PCB. Not all pins are connected so refer to circuit diagram. VGA Pins 9, 13, and 14 are worth checking first.
Use a component lead off-cut (i.e. from a resistor) and insert it into one of the VGA socket holes, then use this to check for any breaks possibly at the point the VGA pins are soldered onto the PCB.
If the monitor cable was 'strained' in some way then it is possible a track is broken (probably more likely to be a sync pin - otherwise you will see a 'strange' colour display if the R, G, or B signals were lost).
Also, do you have the means to reload the firmware? This will eliminate any software related issue (which I have never come across before - but maybe worth doing if the above continuity checks are all ok).
Let us know if you find out what is causing the issue!
WWEdited by WhiteWizzard 2015-07-15
Posted: 04:04pm 14 Jul 2015
Hi Crossty,
are you using VGA or COMPOSITE?
Maybe the option setting has been corrupted and reset back to a mode that cannot be displayed on the screen you are using (sounds the most logical cause)..
It has been a while since I have played with a maximite so I cannot remember the command to st for the various display modes.
Posted: 04:16pm 14 Jul 2015
Crossty,
Have a read of the manual in the CONFIG section and the OPTION section there are commands there that change the way the Video is displayed.
Eg.
CONFIG COMPOSITE NTSC | PAL | DISABLED
or
CONFIG VIDEO OFF | ON
OPTION VIDEO OFF
or
OPTION VIDEO ON
Mik
crosstydown
Posted: 03:31pm 27 Jul 2015
thanks for help !!
i am in vacation
when i return i will try your suggestion and get back to the forum
VK2MCT
Posted: 04:39pm 27 Jul 2015
I suggest sending a photo of the board and where it is.
A greenhouse sounds like a pretty hostile place for a circuit board.
John B.
