Local Time 21:51 12 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : nokia 5110 display
MikeO
Posted: 12:13am 05 Jul 2015
Just using one of these Nokia 5110 displays on a mite for the first time and It appears to be completely dead. I have checked the wiring and also monitored all the I/O , all seems OK, program running, SPI clock,SPI out and data command are all pulsing, chip select low , reset high. Just come to the conclusion it is DOA. Just wondered what others peoples experiences have been, reasonably common or I have just been unlucky? I have ordered new one anyway as two far into the project now.
Mike
Codenquilts
Posted: 07:06am 05 Jul 2015
Try changing the value of the contrast data. &HB9 or even &HBF might make a difference
Edited by matherp 2015-07-06
palcal
Posted: 11:19am 05 Jul 2015
I bought 3 of them, all worked OK but after continued use ( about 10 hrs/week for about 6 months) one of them went dark and was hard to read. I replaced it and now OK again.
Paul.
CircuitGizmos
Posted: 06:41am 06 Jul 2015
http://www.instructables.com/id/Servo-Tester-with-Graphic-LCD/
Edited by CircuitGizmos 2015-07-07
nibbler
Posted: 09:00am 06 Jul 2015
Nice servo tester. I've just been connecting servos to a receiver and eye-balling them. This is a great little project. I would probably put it in a project box. A PCB would be nice but isn't worth it just for one unit.
Have you given any thought to testng modified servos that don't stop but rotate right around? Obviously they're not for R/C use.
Alan
CircuitGizmos
Posted: 10:18am 06 Jul 2015
It'll work just the same with the modified servos. Position offset from the center (1500) will just be speed and direction.
MikeO
Posted: 06:30pm 10 Jul 2015
I was using 4.7b8 when I first reported this issue, I got some new displays thinking I had a dud however I still had the problem. I then tried 4.6b and of course it worked (should have tried that a week ago). It seems that with the change to the SPI Open routine in ver 4.7b8 that you have to let it handle the CS (not as suggested in the manual) by setting the optional argument and removing the I/O control of the Chip Select from within the program. Once you do that the display works as expected.
Codenquilts
paceman
Posted: 08:24pm 11 Jul 2015
Geoff changed the SPI Open method in the V4.7b11 release here which should have fixed this. The other bugs that turned up in beta 11 though made it problematic so he quickly recommended going back until he has time to sort it out properly.
Not sure if the MicroMite+ f/w has it sorted but that wouldn't help with an MX170 build anyway.
Greg
MikeO
Posted: 12:14am 12 Jul 2015
Thanks Paceman, I will stick with 4.7b8 at the moment as its working fine with the Open SPI controlling the CS line. I can always revert to the program controlling when a more stable versions comes along.
Mike
Codenquilts
